Old 01-27-2005, 03:55 PM
GotGrip666's Avatar
GotGrip666 GotGrip666 is offline
Banned
block crack in below freezing temp?
ok today this guy tried telling me that my block will crack if i dont run my car for the next couple of days because its supposed to be -16 degrees here..................i have never once heard of this before and sounds like Bs to me, so will any of our pro's here tell me this myth is busted
Old 01-27-2005, 04:42 PM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
Re: block crack in below freezing temp?
If you dont have the proper amount of antifreeze in your radiator/engine then yes your block can crack... But this is why manufacturers use freeze plugs (little metal caps inserted into the side of your block) so when water freezes and expands, the freeze plug pops out so your block doesnt crack. Although if your freeze plugs do not pop out you have the potential chance to crack your block.
If you have a good mixture of antifreeze and water, I wouldnt worry about it if I were you. My GST has been parked outside for almost the whole winter and my block hasnt cracked yet, its been as low as -36 with windchill here just to give you an example.
Old 01-27-2005, 07:00 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
actually the real reason for the freeze plugs is that they are left over from porting the block after it's cast. freeze protection is just a extra benefit
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 01-27-2005, 10:45 PM
fiberglasscivic's Avatar
fiberglasscivic fiberglasscivic is offline
Send a message via AIM to fiberglasscivic Send a message via Yahoo to fiberglasscivic
I live in Grand Forks ND. The lowest temps I saw here have been -44 without the windchill. If your looking at subzero tempratures for extended periods of time then it would be a good idea to change to a heavier weight oil and or add a block heater to you car. (For those of you who don't know what a block heater is, it's a way to plug your car into an AC outlet to keep your block and oil warm). The other option would be to install a security system with a remote starter that includes a temp sensor. It will start the car automatically when temps reach a set limit. The car starts for about 15 mins, every hour on the hour until the outside temprature warms up. Other than that it is possible for your oil to freeze or the water in your block to freeze and crack the block.
Old 01-28-2005, 07:22 AM
kjewer1 kjewer1 is offline
AF - Advisor
I cant think of anything in the block that is ported, and I cant think of one other reason for the freeze plugs besides to relieve pressure from freezing coolant. Why arent they called "porting plugs?" Also, oil cant freeze. It gets super thick and hard to pump in extreme cold, but it cant solidify at the temps that we see on this planet
I tend to run a higher percentage of coolant/antifreeze in the winter to prevent any potential problems. Up to 70%. In the summer I run quite low, mostly water. MAybe 30-40%. Water is a better conductor of heat, just need some coolant for boilover protection, lubrication, and corrosion prevention.
I can see coolant freezing at -44 though, thats damn cold. Follow the coolant manufacturers recomendations for what percentage is required to protect to a give temp.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 01-29-2005, 09:41 AM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Re: Re: block crack in below freezing temp?
Yep, they are from casting and not for freezing. They've got the that term because they CAN pop out when freezing but they are not designed to. I've seen plenty of cracked blocks from idiots not properly checking their antifreeze. On those blocks, the freeze plugs never moved at all.
Silverado Ext. Cab 4x4 z71
Pioneer 4900mp
Orion P6.2 Componet sets front
Orion C63 Coax rear
DirectedVideo 9" all in one DVD with surround
2007 SATURN OUTLOOK AWD XR with full entertainment package
Old 01-31-2005, 12:21 AM
Nayr747's Avatar
Nayr747 Nayr747 is offline
THIS is when you know your car is too cold!
'99 GSX, 5-speed, 60k miles: Greddy filter / RRE uicp / 1g bov / Autometer boost gauge / Injen-copy intake / Megan DP (not installed)
Coming soon! Thx to Blackcrow & nova1313! http://dsm-one.org/
Adopt pets in need! http://www.petfinder.com/
Old 01-31-2005, 12:55 AM
Urban_Squrill's Avatar
Urban_Squrill Urban_Squrill is offline
Send a message via AIM to Urban_Squrill Send a message via MSN to Urban_Squrill
Wholy shit!
Blowing motors since 2005.
1995 Eclipse GS 5 Speed(White)
1995 Eclipse GSX 5 Speed(Silver)
Need a file hosted? IM me.
For Sale:Fidanza Flywheel, 7 Bolt AWD $120 Will take trades too.
Originally Posted by EclipseRST
Thats like fucking glitter...
Old 01-31-2005, 01:26 AM
george536's Avatar
george536 george536 is offline
Originally Posted by Nayr747
why is the van ok?
-1997 Eclipse Spyder GST |Stock|
-1990 Eclipse GSX
|ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar|
Old 01-31-2005, 01:40 AM
randypalmer15 randypalmer15 is offline
I don't think you should have much to worry about, minus-26 C (minus-16 F) isn't too bad if you have a strong battery and let the thing warm up before putting any serious RPMs on it.
We endured a week of -39 C, -50-plus with the windchill weather for about two weeks here in Moose Jaw at the start of the month, and there were still cars running all over the place. Hell, even my Dodge Shadow POS ran like a top (I didn't even plug the damn thing in and it still started without a problem. Battery from hell, baby!). It's harder on them, for sure, but as long as you don't push the hell out of them when it's that cold it shouldn't be too bad.
Old 01-31-2005, 01:51 AM
AF - Advisor
Man, I hope those cars have remote starters and they left the heat on. I'd just run that bitch for half a day and hope for the best.
Kevin Jewer
Old 01-31-2005, 07:25 AM
macder macder is offline
Send a message via MSN to macder
Re: Re: Re: block crack in below freezing temp?
Are those pics from the ice storm the hit Quebec few years ago?
Originally Posted by george536
why is the van ok?
I'm thinking he/she parked in the garage.
1993 Eagle Talon ES (4g63NA)
14.6 @ 98 mph (110 octane race fuel)
-5 Speed Transmission (From a 4g67)
-Stage 2 Crane cams
-Ported and polished head
-Aggresive valve springs
-2.5" Custom made exhaust piping
-Custom header
-Gutted catalytic converter
-Bored 0.5mm
-Advanced ignition timing (CAS) aprox. 5 degrees (set @ ~10deg BTDC)
-2g valve lifters (Lifter noise returned, now it a true DSM)
-K&N w/modified air canister
Old 01-31-2005, 08:40 AM
GotGrip666's Avatar
Banned
the antena looks like a huge you know what lol
Old 01-31-2005, 06:08 PM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
pour koolaid on it and tell the kids to start lickin!!!!!!
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
Old 01-31-2005, 07:02 PM
Nayr747's Avatar
Re: Re: Re: Re: block crack in below freezing temp?
It's Geneva. The van might have just parked there right before the pic was taken. That antena is funny though.
http://www.skyandsummit.com/Glacegeneve/index.html
