Old 01-27-2005, 03:39 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
wheres my oil going???
ok, blue smoke means im burning oil, not doing that (i am but verry little and its because its burn off from the sea foam i use to clean it out) no oil on the drive way, and i painted the tapper cover florecent pink (only to check for oil nothen fagish) and ive got some commen out of the back, maby a drip or two, like i said not enough to have any on the driveway and its commen out on the intake side... any ideas and help are greatly apreciated, thanks
Old 01-27-2005, 04:01 PM
CBURKE's Avatar
CBURKE CBURKE is offline
Re: wheres my oil going???
man i am haveing the same prob. i do my oil change and like a mo later there is almost no oil left. everyone said, do a comp test and make sure your timing is on point. othere than that i don't know.
98 MITSU GST, 1990 TURBO MOTOR
98 ACURA INTEGRA LS
88 HONDA CIVIC HB
97 HONDA CBR 600
91 HONDA CRX DX
89 JEEP
Old 01-27-2005, 04:02 PM
2ndb18's Avatar
2ndb18 2ndb18 is offline
Send a message via AIM to 2ndb18
How much oil are u losing. And u are probably burning it. Everytime u take it to high rpm's it will burn more.
88 civic dx
Old 01-27-2005, 04:08 PM
dont have the money for a compresion test, and timeing is on, while im at it, how much would a refurbished tranny cost me and how hard is the drop and re install (98 crx dx 5 speed manual) my centro assembly is shot and it grinds bad going from first to second and when i put it in reverse, yes the peddle is to the floor and its disengauged all the way
Old 01-27-2005, 04:13 PM
ive lost a qrt a week, well i placed 2 qrts in it 3 weeks ago, and today it was bone dry, it had enough in it it only needed 2 to fill it up, and its bone dry now, and why only high rpm's?
Old 01-27-2005, 04:17 PM
CBURKE's Avatar
thank you!!! someone tells me that. i drive hard all the time. but i am lossing about 2 to 3 courts a mo ruffly. as for a comp tester they are $30.00 from you auto parts store.
98 ACURA INTEGRA LS
88 HONDA CIVIC HB
97 HONDA CBR 600
91 HONDA CRX DX
89 JEEP
Old 01-27-2005, 04:18 PM
i gues i can swing that, im looken 1250 for a new tranny unless i do it myselfe
Old 01-27-2005, 04:28 PM
2ndb18's Avatar
Ya, u have bad rings or something like that. That is alot of oil. At school there is a maxima that is doing the same thing. Its rings were shot.
Its not that hard to put in a new tranny. 1250$ is very high. U could put a new a6 and si tranny in yor car for that. lol
88 civic dx
Old 01-27-2005, 04:46 PM
and thats if i let the dealer have his way with me
Old 01-27-2005, 08:14 PM
88CiViC_D-15's Avatar
88CiViC_D-15 88CiViC_D-15 is offline
Send a message via AIM to 88CiViC_D-15 Send a message via MSN to 88CiViC_D-15
do u have an exaust on your car?? i knew my car was burning oil, but soon as i put a exaust on my car, i could really tell how bad it was. thats how i could tell where all of my oil went to
Team Lonely Drivers IS LOOKING FOR MORE MEMBERS,CLICK HERE
TLD FOURMS
- 88 civic std w/ sohc zc swap
- 88 integra ls, stock
- lookin for a 4dr. runnin or not
Old 01-27-2005, 10:16 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
could also have bad valve seals, i just re-build my ZC, didnt bother to put new valve seals in and i'm kicking myself right now because of it, i drive my car hard and loose a fair bit of oil, it sucks too because i'm running mobil 1 synthetic which isnt cheap
Old 01-27-2005, 10:20 PM
no, no its not... as for an exhaust, it goes from an exhaust manifold, to pipeing, to an exhaust tip, are you sayen i need a muffler and cat to see blue smoke????
Old 01-28-2005, 12:13 AM
no, when i upgraded my exaust to a 2.75 inch tubing, it made a hella of a diffrence of the smoke i could see, it poored out like i was using more oil than gas, i knew a few other people who had the same prob. when i had the stock exaust on it, didnt see the blue smoke as much comparted to when i put the new exaust on.
TLD FOURMS
Old 01-28-2005, 10:12 AM
big bad mohawk guy's Avatar
big bad mohawk guy big bad mohawk guy is offline
rings my is doing the same thing. they are $66 for stock and $77 for top of the line.
1988 crx hf
cool air intake
#1 racing exhaust
sprint spings
B&M SHORT SHIFTER
gutted cat.
Old 01-28-2005, 11:31 AM
4-Door Flunky 4-Door Flunky is offline
AF Premium User
Oil Burning
When I was commuting over 500 miles per week at 85 MPH and up (I'd crank it up to 95 MPH before this really long, steep hill called La Bajada on I-25), burning 2 quarts per month was normal.
If you crank it up to the high rpms every shift and drive over 80 mph, you car will burn more oil, no matter how good your rings are.
Drop your highway speed to a little bit under 80, and that'll stop. Try it for a week, if you have the discipline to stay off the pedal, and you prove it to yourself.
Flunky
