Old 01-27-2005, 03:02 PM
af62cobra af62cobra is offline
Send a message via AIM to af62cobra
stopped and no start
my sons 95 talon stopped and will not start or make any sound no power battery is good, no lights or any power fuses are good.could problem be computer.men i need HELP i'm not a import man.i'm a ford man.
alden
Old 01-28-2005, 10:18 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: stopped and no start
The easiest thing to check would be the battery terminals and the grounding strap on the battery. Any corrosion on the terminals should be cleaned and make sure there is no damage to the ground. Let us know what you find.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 01-28-2005, 03:29 PM
GSTRacerNVUS GSTRacerNVUS is offline
alden
^^ Definately check the ground. If there's greenish white crap on the terminal or ground, you can clean it up with some water and baking soda.
In addition to that, although this is a car forum, do not assume there are no females amongst the crowd.
97 Eclipse GST MT
Race Every Day Like It Will Be Your Last.
My one insignificant mod: Dump Tube - CUT
Old 01-30-2005, 09:02 PM
northriverflames northriverflames is offline
Send a message via MSN to northriverflames
Check your fuses, and as odd as this sounds, check to see if your battery isnt cracked, like alot of dsm's the battery "holder.." or "black bucket the battery sits in" could be missing, then the battery can get thrown around and crack.......and Chicks driving Dsm's ROCK!
Old 02-01-2005, 05:51 PM
first and formost i didn't mean to offend any of the women and/or ladies that like hot cars, if i did i'm sorry.i have checked all the cables with a meter,does the talon have fuse links.i have check the battery and it will start my 347stroker just fine.
