COPY/PASTE~~~>
WWW.METRONWK.BRAVEHOST.COM <~~~ WATS GOOD I GOT A 95 PRELUDE SI/SR (SILVER)THE PICS ARE WHEN THE CAR WAS GETTING DONE EMAIL ME FOR THE MOST RECENT PICS THE CAR HAS 114,000 BUT ENGINE HAS NOT EVEN 5 MILES YET THE CAR HAS NEW PISTONS,PISTON RINGS GASKET SET THE BLOCK IS A H22A ITS PORTED AND POLISHED THE BLOCK IS 96 THE HEAD IS 99 DOHC VTEC THE HEAD ITS DOUBLE SPRINGED AND IT ALSO HAS NEW VALVE SEALS AND HEAD GASKET, NEW WATER PUMP, NEW TIMMING BELT, NEW THERMOSTAT ,SPARK PLUGS ,NEW MASTER CYLINDER AND SLAVE CYLINDER A.C.T HIGH PERFORMANCE CLUTCH AND PRESURE PLATE LIGHTEN FLY WHEEL IT HAS SOME 16'''''''''''''''' BLACK RIMS GENERATION 3 TAILLIGHTS THE CAR IS CLEAN IT HAS THE AGX ADJUSTABLE SHOCKS WITH THE SKUNK2 SPRINGS IT HAS CATBACK EXHAUST CHIPPED P28 ECU The engine redlines at 8,000 rpm. Long gear ratios.(example, in third gear VTEC kicks in at around 5,200rpms @ 80mph and you do not have to shift into 4th untill 110mph @ 8000rpms.)This car has a rebuilt engine which should be good for up to 40 pounds of boost. Power is at 299hp & 284 torque. This is the max the turbo will put out 19-20 pounds if buyer installs turbo....IM TAKING OFFERS TRADES ARE WELCOME EMAIL ME A
[email protected].........NO DUMB OFFERS 3K INVESTED IN ENGINE ALONE TOO MUCH $$$$ INVESTED...........EMAIL ME FOR PICS OR YOU CAN HIT ME ON THE TWO WAY 183*142*3570 ONE
WWW.METRONWK.BRAVEHOST.COM im located in newark new jersey
