I am trying to remove my signal lights, and replace with aftermarket lights. I am not able to get to the wiring in the back to remove fender and signal lights, also having problems with the front. If you have any idea how I can get this done, please help. Also if you have an idea of the wiring or diagram that would be great. Thanx
What kind of bike???
DarkTint 1999 Grand Prix GT 2-Door 2008 Honda CBR600RR |
the topic suggested some intersection mayhem.
I'm the greatest! |
I'm sorry, the bike is a 2003 Kawasaki Z1000.
Re: Signal light HELL!!!!
Yes, I thought this was going to be about the intersection lights not changing to green when you're on your bike.
I approved this message. |
can't give specific info on your bike but most are very similar.
for the rear you'll have to remove pretty much all the plastics on the tail to get to the harness. don't cut the plugs off your indicators. use line taps (special connectors that enable you to join a new wire to an existing one without cutting) on the socket side of the connector. as for the front there may be an inner fairing that needs to come off as well as the outer depending on the mounting. with mine i can get to my harness without any removal of any plastic on the front
Ok thanx I think that will help I will give it a try then I'll try to get the front started. Thanx again |
Check out www.buykawasaki.com for exploded parts views of your bike. May help you find out how it comes apart.
Re: Re: Signal light HELL!!!!
