Old 01-27-2005, 10:12 AM
Laaars Laaars is offline
Panel Lines
Hi!
I'm soon finished building a Calsonic GT-R.
I did a quick search on Panel Lines, but got so many different answers so I'm taking the risk of asking some questions here...
1. Which color should i use? The car is painted in TS-44 "Brilliant Blue". Black? Dark grey or smoke?
2. What is the best way to do this? I don't have any gundam marker so I'll use the acrylic paint. Can i thin it out in water? I think that will be easy to remove if I get outside the lines, or I may be wrong... If not, can I thin it out in the Tamiya X-22 (Clear)? I don't have any thinner here now so...
I'm a little afraid to paint outside the line because i have no compound or anything to remove it with... or does it get of with just paper if I'll remove it soon enough?
Thanks!
Old 01-27-2005, 10:56 AM
Scale-Master's Avatar
Scale-Master Scale-Master is offline
This is what TS-44 looks like with black door lines, you may want to consider dark gray with a touch of blue.
You can use water, but Tamiya acrylic thinner or Windex will work better and dry faster.
You should be able to use wax to polish away any paint you get out side of the lines... - Mark
Old 01-27-2005, 11:18 AM
Re: Panel Lines
Maybe a bit too black I think... I'll try dark grey with some blue in.
Polish with wax? As in normal car wax?
Thanks!
Old 01-27-2005, 11:20 AM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Best piece of advice on panel lines I can give is :
Don't overdo them.
Few things can make a well built model look more toylike than thick, dark panel lines. So, black is right out. Medium to dark grey would be a good bet, Tamiya smoke is probably better. I'd thin it with Windex glass cleaner or similar, and apply with a pointed brush, to let it flow into the engravings, and wipe up any excess with a bit of paper towel. This won't damage the laquer, so if it doesn't look right, you can wipe it up and try again.
PHOTOBUCKET SUCKS
Old 01-27-2005, 11:51 AM
Technoman's Avatar
Technoman Technoman is offline
Re: Panel Lines
Whats best to use over Tamiya acrylic paints?
Old 01-27-2005, 12:13 PM
Probably water colors over acrylic.
Remember, the darkness of the panel line is actually a shadow of the body color on a real car.
It may look black at first glance, but if you study it you will see a tint of the body color in that shadow line... - Mark
Old 01-27-2005, 12:29 PM
Re: Panel Lines
Aha, I think I'll go for the smoke color then. Thinned out in water i suppose, unless I find some glass cleaner or something around
Old 01-27-2005, 12:33 PM
If you don't have Window Cleaner you can mix a thinner with Rubbing Alcohol and Ammonia. Test first to make sure it doesn't react with your paint. - Mark
Old 01-28-2005, 05:44 AM
Amazon's Avatar
Amazon Amazon is offline
Re: Panel Lines
I have a different thing for you guys: i use thinned artist oil paint ( black, but you can use any shade/color you want) and a fairly small brush (3/0). Since it`s thinned the cappilary action makes the paint run byitself. I`ve used it on both Tamiya and Humbrol paints.
Newsflash: Diecast sales fund terror activities.
Old 01-28-2005, 06:31 AM
Re: Panel Lines
I made the panel lines today.
I used a small bamboo-stick to use with food and used the tip into the panel lines. Came out pretty great.
I don't hope the Acrylic paint reacts with the Tamiya clear coat? If so, i have really screwed up... hehe.
Old 01-28-2005, 07:16 AM
Vric's Avatar
Vric Vric is offline
Re: Panel Lines
Best way is gundam marker.
If you want to use paint, see this:
http://italianhorses.net/Tutorials/Panelines/panels.htm
Old 01-28-2005, 09:52 AM
Re: Panel Lines
Thanks, I'll try that on my next model.
The clear coat is dry now and I see it reacted with the acrylic paint i used for the panel lines. Doesn't look too good, but its my first serious model so... I'll learn by my mistakes.
Old 01-28-2005, 09:54 AM
What clear did you use? - Mark
Old 01-28-2005, 10:00 AM
Re: Panel Lines
The Tamiya TS-13, and the panel lines was painted with Tamiya X-19 Smoke.
Isn't it supposed to react? Maybe it wasn't 100% dry? I waited a while, but maybe i should wait even longer...?
Old 01-28-2005, 08:16 PM
Not being dry was my first guess. I'd give the acrylic at least 24 hours before hitting it with that clear. - Mark
