Old 01-27-2005, 11:11 AM
bully06 bully06 is offline
Question blower motor resistor location 01 T&C
My blower motor only works on high for my front and rear heat on my 2001 town and country, I noticed in this forum that this is a common problem with Chrysler vehicles. I would like to check the blower motor resistor and wiring, but I need to know where it is located. Any guidance would be appreciated.
Thanks to all
Old 02-02-2005, 11:53 AM
michigancarguy michigancarguy is offline
The blower motor resistor is located under the dash on the passenger's side of the vehicle. There is a medium-sized multi pin conncector and associate harness attached to the resistor. Once the wiring harness has been unplugged at the resistor you can remove the two small small screws, one on either side of the resistor (I used a really small wrench). There is a small rubber gasket that can be re-used with the new resistor. I paid like 10 bucks at a dealer for the part and it takes about fifteen minutes to replace. The dealer wanted $110 for the repair.
