Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 01-27-2005, 08:26 AM
hatchcivic hatchcivic is offline
Send a message via ICQ to hatchcivic Send a message via AIM to hatchcivic Send a message via Yahoo to hatchcivic
Timing belt
I'm still in the process of buying a 93 Rodeo, and I asked the owner about the replacement of the timing belt and he never changed it but he has not owned the car but just over a year now.If i get this rodeo I'm going to change the timing belt right a way what Do I need to replace with that belt. Thanks
Old 01-27-2005, 08:51 AM
Slade901's Avatar
Slade901 Slade901 is offline
Banned
Re: Timing belt
What's the mileage?
If the mileage is close to 60,000 miles or over, it's time to replace the timing belt as well as the tensioner.
Old 01-27-2005, 08:53 AM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: Timing belt
Not sure on the tools needed but make dang sure you replace the timing belt tensor with it. If not, within the first 20k the old tesnor will start to slap around and sound like rod knock.
Also, if your truck has over 100k, and you have no history on the water pump, I would also, swap that out to.
-Ryan
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 01-27-2005, 08:57 AM
Re: Timing belt
Thanks for the info, It has 128,000 miles on it. thanks
Old 01-27-2005, 03:39 PM
Volkswagon Volkswagon is offline
Re: Timing belt
adjust the valves too.
Old 01-27-2005, 04:08 PM
Ramblin Fever Ramblin Fever is offline
Re: Re: Timing belt
Only with the 4-cylinder; there's no adjustment needed on the V6 3.2L or 3.1L.
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 01-27-2005, 04:32 PM
rodeo02 rodeo02 is offline
Yes, being a 1993 3.2L with 128K miles, you will need: 1) T-belt, 2) T-belt tensioner pulley, 3) T-belt tensioner pushrod assembly, 4) Water pump. You will not sustain any engine damage should the T-belt break on the fly (non-interference engine), the engine would just stall out, crank, but not start. No valve adjustements are needed on the 1993-1997 3.2L since they have hydaulic valve lash adjusters ("lifters"). If you are short on $$$ and dont mind driving it as is, wait until the water pump starts to dribble coolant, then change out the whole nine yards.
G/luck!
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 01-27-2005, 05:02 PM
Re: Timing belt
Does a 99 passport 3.2 have hydaulic lifters? I used to adjust Chevy V8 hydaulics bad in the muscle car days, is this not the same process?
Old 01-28-2005, 06:06 AM
Re: Re: Timing belt
No. The 1998-2004 3.2/3.5 do not have hydraulic valve lash adjusters. They have a 'direct acting' valve actuation setup, where the cams sit directly above the valve stems (no rocker arms). There is a shim & bucket between the cam lobe & valve stem. The shims are replaceable to adjust valve lash. Isuzu only recommends checking clearance "if noisey" IMHO- these engines are *clickedy-clickedy* all the time, so I guess you need to listen for a constant,steady,LOUD top end tap.
G/luck
Joel
