Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 01-27-2005, 08:11 AM
mckenzi mckenzi is offline
Unhappy Klunking noise when shifting from park to drive
I have 1 1995 Gmc Jimmy 4x4 automatic just bought 2 days ago. It consistently makes a loud klunk noise when I shift from Park into drive, but makes no noise at all shifting from park into reverse, sounds like it is beneath the center of the vehicle,or driver's side. It also has the loud whining sound that I have seen mentioned elsewhere on the forum, it only makes the whine above 55 mph, will try those suggestions but was concerned about this klunk, I checked transmission fluid and it was full.
Mckenzi
Old 01-27-2005, 12:49 PM
troubles789 troubles789 is offline
Re: Klunking noise when shifting from park to drive
Check your torsion bar mounts. One on each side. If one goes bad, replace the pair.
Old 01-27-2005, 02:09 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
U-joints.
Have them inspected.
Probably the rear u-joint right in front of the rear differential.
Had the same problem and that is what fixed it two weeks ago.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 01-27-2005, 03:26 PM
Sputnik13 Sputnik13 is offline
BlazerLT, what are you telling mckenzi to check the U-joint for? The klunk or the whining sound? I get a similar klunk sometimes from my car but not the whining sound. I do sometimes get a scratchy/whiny sound when I have either my AC or heat on. It seems to kind of lessen when I'm breaking but then it starts up again when I'm stopped. It's weird, and it doesn't happen so frequently that I can really describe it accurately.
Old 01-27-2005, 04:32 PM
BlazerLT's Avatar
AF -Advisor
The clunk and the whining could be from a dry and worn out U-joint.
Also, best to check the transfer case and differential fluid levels and have the fluid changed if it has never been done.
Old 01-29-2005, 12:04 AM
Mckenzi
The torsion bars looked ok, I will try the U joints next and differential fluid, purchased used not sure whether it has been checked. I really want to get rid of this whine, it worries me because it is always there, I have nothing but highways around me so 55 is a contant and it starts at that speed. Called local GMC dealer today and found an open recall for ABS which I will have repaired Monday, they want $80.00 to disgnose other problems though. Thank you
Old 01-29-2005, 08:22 AM
BlazerLT's Avatar
AF -Advisor
Should be the U joint.
My rear U-joint has been replaced twice since new.
Old 02-01-2005, 07:29 AM
Smile Resolved klunking and whining noises
Thanks so much for all your help. I had the 95 Jimmy checked out yesterday at the dealer because there was a recall for something and they did say that both the front and rear u-joints were worn, I had them replace them for $325.00, too cold here to do it yourself, and the klunk upin shifting into drive is gone AND the whining at 55 and above is also gone, I am so relieved, killed two problems with one repair.
Old 02-01-2005, 03:25 PM
BlazerLT's Avatar
AF -Advisor
Nice! Glad to have helped you.
