Old 01-27-2005, 12:58 AM
cpurser cpurser is offline
F-150 starting problem (tough one!)
I have 1990 F-150. When I start it cold, it starts just fine and runs just fine. But, when the engine heats up, and I turn it off, it won't restart,(starter does crank) until the engine temp cools down (about 45 min). Possible electrical problem? Fuel problem? Ignition?
Any ideas?
Old 01-27-2005, 01:28 PM
mstrred mstrred is offline
Send a message via MSN to mstrred Send a message via Yahoo to mstrred
sounds like the starter solenoid to me
Old 01-28-2005, 06:28 AM
Mialo Mialo is offline
I had the same problem. Thought it was the starter overheating. I removed it and went to parts store that was out of stock I reinstalled the old starter and installed a new neg. batt lead. Have not had another problem since and its been 4 months. Good luck
Old 01-28-2005, 10:45 AM
Start is cranking
For some reason, I don't think it is the starter, because it is always cranking over, but the engine doesn't start. Even when the motor is hot, the starter cranks.
Old 01-29-2005, 03:40 AM
FORDTRACMAN FORDTRACMAN is offline
Re: F-150 starting problem (tough one!)
Check fuel pressure.Could be a fuel pressure regulator.
Old 01-29-2005, 04:50 PM
TheFordSupremacy TheFordSupremacy is offline
Send a message via AIM to TheFordSupremacy
I had the same problem with my 91, I swear it's your ignition module, pop it off get it tested, they it'll get hot and fuck up, mine did, sounds like it to me.
Old 01-30-2005, 12:50 PM
c150L c150L is offline
If this has the TFI module on the side of the disty, that thing is known to go out. Heat is the issue. Not sure what years, but there is/was recalls on them. (Ford garage might not admitt such a recall exists.) I'd also suggest NOT installing a used one unless one is available just to test out. If testing with a used module, I'd replace with a new one after you think it took care of your hot starting problem and before the used test unit does the same or worse on you at the worse possible time.
If this has a disty and no TFI module on it, or is a disty-less ignition, I'm not sure what to tell you for narrowing it down.
Do come back and let us know what was found or further info.
Old 07-09-2005, 11:11 AM
tvine00 tvine00 is offline
Any ideas?
Your symptoms describe exactly what my truck did. It was a coolant temperature sensor. When your engine is warmed up, and the sensor is faulty, it thinks the engine is to hot. Its cheap and easy.
Old 08-07-2005, 10:54 AM
Robin Hood Robin Hood is offline
I had this problem and it turned out to be the coil.
Old 12-17-2006, 09:12 PM
dmhitt825 dmhitt825 is offline
I had the same problem with my 300 6cyl try replacing your Coolant Temp. Censor. I know it dont make sense but trust me the same exact problem stumped me for a while but its a fairly cheap part if i remember right its about 20 dollars
Old 12-18-2006, 03:06 AM
mechhound mechhound is offline
This is an old post, but I'll answer anyway. It's either the coil or the stator. You can't really test these components unless you catch them in a dead(non-running) state. If you test them in a live (running) state, they will test good anyway. So you pretty much have to go trial and error. So try the coil first because it's cheaper and easier to replace. If the coil doesn't fix it go with the stator. You have to remove and disassemble the distributor to replace the stator. The ignition module on the side of the distributor also goes dead, but when it dies it is dead for good.
