Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 01-27-2005, 12:50 AM
phraley phraley is offline
what could be running my battery down
I purchased a 2002 sc1 last week and the battery was dead the next day and for next five days .I purchased a new die hard and it still dead the next morning. Has anyone had this problem?
Old 01-27-2005, 06:16 PM
sickcallawayc12's Avatar
sickcallawayc12 sickcallawayc12 is offline
Does it crank or do nothing at all when you try to start it? This will help a lot. Any clicking? Check wire connections at battery; make sure they are tight and aren't corroded. Check all your fuses.
Old 01-27-2005, 11:23 PM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
Re: what could be running my battery down
make sure none of the lights are staying on, including the trunk light.
otherwise, you will need a multimeter/ampmeter. or the getto way of doing it, pull 1/2 of your fuses, if the next day the battery is dead, the next night pull the other haft, which ever haft is draining the battery, the next night pull 1/2 of the 1/2, continue doing this until you are down to one fuse.
no thank you for that. to complex and slow for me, give me a multimeter and i'll do the same job in 20 minutes.
