Old 03-13-2002, 07:48 PM
johnny1329 johnny1329 is offline
How to adjust timing on a doch ?
I have a ford probe 2.0 and i need to konw how to adjust the timing, please help
Old 03-13-2002, 09:19 PM
ivymike1031 ivymike1031 is offline
Send a message via AIM to ivymike1031 Send a message via Yahoo to ivymike1031
I assume that you mean "ignition timing," right? If you have a distributor, the most common method of adjusting the timing is to loosen the clamp bolt where the distributor meets the head, and turn the distributor one way or the other. Use a timing light to check the setting. Consult a service manual for detailed specs about the procedure on your particular vehicle.
Come on fhqwhgads. I see you jockin' me. Tryin' to play like... you know me...
Timing Adjustment Question JAGSARGE F Series 4 05-31-2010 04:50 PM
How to adjust valves? lazerphreak Engineering/ Technical 1 05-08-2009 06:22 PM
94 3.2L How to adjust timing belt tension? nujac Trooper | SLX | Bighorn | Wizard 10 10-29-2006 04:36 AM
Urgent- How To Adjust Timing 94 Cav? alexbh Cavalier 3 11-03-2004 04:24 PM
94ss w please tell me how to adjust timing 94sser S-10 11 05-26-2004 10:29 PM
