Go Back   Automotive Forums Car Chat > Hyundai > Accent | Verna
Old 01-26-2005, 11:07 PM
mr.cool mr.cool is offline
clutch problems? please help!
Several weeks ago my clutch felt like it started to go.
I had no feel to the clutch pedal, as if nothing was there. Almost every gear ground hardcore each time, especially reverse, it would often take me multiple tries to get 'er into first.
I took it to a local guy. He checked it out, bled my hydraulics. He told me nothing really happened...that air had somehow gotten inside, dramatically reducing clutch movement.
Needless to say a few days later the problem returned.
Do I have a faulty cylinder? Or do I need to replace my clutch?
Anyone with advice is GREATLY appreciated. Thanks in advance.
Old 01-27-2005, 08:01 PM
civic16 civic16 is offline
Re: clutch problems? please help!
i have 2 suggestions. 1 test the clutch by putting the car in third gear and let up on the clutch kind of quick if it doesn't stall the clutch is worn.. the farther up the gear the worse the clutch. 2 if the clutch cilinder is vacum fed check for vacum leak.
Old 01-31-2005, 09:56 PM
Re: Re: clutch problems? please help!
I can put into third gear with ease. In fact, third would probably be the softest gear.
Vacuum leak huh...I'm not sure if it is or not. How would I know whether or not the cylinder is vacuum fed?
Old 01-31-2005, 11:01 PM
mazdatech mazdatech is offline
your slave cylinder is not vacuum fed......guarenteed! In fact i am unaware of a slave cylinder that is vacuum fed anywhere/ever!
