Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 01-26-2005, 10:22 PM
FourWheelDiver FourWheelDiver is offline
Wrangler(TJ) hard start
I have a 2002 4.0 TJ, 40K, well maintained. When restarting after engine is warm, engine does not catch, and sounds like battery is draining. If I wait a few minutes and try again most times it starts right up. When the engine is cold No problems. The only scheduled maintenance not done is fuel filter replacement, (is it in the fuel pump in the gas tank?). Also had battery checked and was told it tested fine. Strange thing is, my friend has a 2002 2.5 auto and it is starting same thing with much less mileage 25K. I would be grateful for any insights. Thank you in advance.
Old 01-27-2005, 09:23 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: Wrangler(TJ) hard start
Do a search on this forum, the same problem has been had by other folks too. It could be the crank position sensor, a failing fuel pump or a clog in the fuel filter if I recall correctly.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
