Go Back   Automotive Forums Car Chat > Ford > Mustang > Performance
Performance Discuss Engine, Suspension, Drivetrain, and all other performance modifications here.
View Poll Results: brand of chip
superchip 2 66.67%
jet 0 0%
bulldog 0 0%
or go with tuner 1 33.33%
Voters: 3. You may not vote on this poll
Old 01-26-2005, 09:51 PM
j12racer j12racer is offline
chips
good? bad? what brand? on a 97 v-6 stock stang
Old 01-26-2005, 09:56 PM
dampachi's Avatar
dampachi dampachi is offline
Banned
Send a message via AIM to dampachi Send a message via MSN to dampachi Send a message via Yahoo to dampachi
Re: chips
I usually prefer lays potato chips as opposed to utzs and herrs. The baked ones. Mm.
Old 01-26-2005, 10:16 PM
silverstangs's Avatar
silverstangs silverstangs is offline
Send a message via AIM to silverstangs
Re: chips
Hypertech or Diablo will work.
You have not done enough mods to warrent a dyno tune or custom chip.
My ride at my site Silverstangs.
Old 01-27-2005, 09:23 AM
stang_00 stang_00 is offline
Send a message via MSN to stang_00 Send a message via Yahoo to stang_00
Re: chips
i would say diablo
Old 01-27-2005, 10:20 AM
ModMech's Avatar
ModMech ModMech is offline
Re: chips
For the BEST in Ford tuning, see the folks at SCT. They alone can change ANY EEC parameter you wish, and do it properly.
www.sctflash.com
Old 01-29-2005, 12:04 AM
eillob's Avatar
eillob eillob is offline
Silverstang is right. A chip or custom tune of any sort is a total waste on a stock car. You would get more from your money going with gears or some sort of intake or exhaust mod. Save the chips and custom tune when all your mods are done.
Ported Cobra Intake, Ported & polished Windsor Jr heads, K&N, Vortech s-trim, 90mm Lightining mass air meter, 70mm throttlebody,1.7 roller rockers, BBK Long tube headers, offroad H-pipe, Crane cam, main cap girdle, 40 series flowmaster, 3.73 gears, MSD ignition, CGS subframes, A9L PIH kit, SCT custom burned chip, 42lb injectors, 190lph fuel pump, T rex and fuel pressure regulator, AFCO racing radiator
(If it doesn't scare the Hell out of you it isn't fast enough)
Old 01-29-2005, 02:29 AM
ModMech's Avatar
Re: chips
I hardly consider $10/hp a waste, you might, I do not.
Old 01-29-2005, 10:00 AM
eillob's Avatar
Well on a stock car I call it a waste here's why.
You have three options the way I see it. You can go with an off the shelf chip like hypertech or Jet. You can get a dyno tune and get a custom burned chip that will carry a custom program specific to your car or you can get an EEC Tuner.
Off the shelf chips are the cheap way out and because of that your not getting the most for your money, its a generic program good for any vehicle and all they really do is advance the timming which you can do yourself. In automatics they delay shift points, big deal.
Then there are custom burned chips which is the best way to go for a chip. Why because your car is put on a dyno and given a program based on YOUR cars performance on the dyno. The chip will have a program on it specificly designed for the parts on your vehicle so you will get far more performance for your dollar over an off the shelf chip. The only problem here is if you get a custom burned chip for a stock car everytime you do an upgrade to the vehicle this chip will have to be reburned in order to get anything out of the upgrade. This can get way expensive if your starting out with a stock vehicle and you've got plans on more upgrades in the future. Which was my point from the get go.
The EEC tuner is the best way to go (also the most expensive) because it allows you to make changes to the vehicles program any time you make a change to the vehicle. A tuner will run you upwards of $600. which Ill say again is a total waste on a stock car.
Old 01-29-2005, 01:44 PM
dampachi's Avatar
Banned
Re: chips
Has anyone noticed all the related links are for/about potato chips? haha. On a stock motor one of those little tuner thingies will probably muster up about 3-5hp. Is it $30-50? If so, then go ahead and buy it.
Old 01-29-2005, 03:38 PM
ModMech's Avatar
Re: chips
SCT REGULARLY sells custom, made to order chips for $400, and you can EXPECT a 40 RWHP, yes WHEEL HP gain on an '05 4.6L 3V.
Figure it out, $10/HP.
BTW, SCT tunes, everyone else toons. Like it or not, it is the truth.
Ask ANY other "tooner" what they offer for a 3V, and what dyno-proven gains and transmission (A/T) functional improvements they make. All you will hear is either BS marketing hype, or crickets.
Old 01-29-2005, 03:59 PM
dampachi's Avatar
Banned
Re: chips
Prove that a totally stock 05 GT mustang gained 40rwhp with nothing more than that tune.
Old 01-29-2005, 05:53 PM
ModMech's Avatar
Re: chips
Since I do not own one, I cannot "prove" anything.
However, reported STOCK numbers for the '05 GTs are 255 WHP, and SCT tuned ones range from 280WHP (early software) to nearly 295 WHP for the later software versions.
The information is out there, if you need the proof, go get it.
Old 01-29-2005, 09:15 PM
dampachi's Avatar
Banned
Re: chips
I'm sure theres a nice little asterik next to those numbers with a disclaimer saying "with minor bolt on modifications."
Old 02-03-2005, 08:32 AM
Laxxplyr Laxxplyr is offline
Re: Re: chips
You know, that is all nice and everything for all of us out there that own a 2005 3V Gt, but, if you took the time to look, this guy is driving a stock 6 cylinder.... not the proclaimed "most productive NA mustang motor yet" this guy will NEVER get $10/hp out of his car with a computer upgrade. He needs to just buy an older SN95 GT, with a 5.0L.... no replacement for displacement.....
Old 02-03-2005, 02:12 PM
dampachi's Avatar
Banned
Re: chips
Even with an 05 GT you're not going to be getting no $10/hp. Yay! Marketing hype!
