Old 01-26-2005, 09:06 PM
pitbullgst pitbullgst is offline
Question stock bypass valve?
I am making a low boost v8 setup for my rx7 and have a buddy who has a extra vr4 stock bypass valve. how much can these hold before they start to leak?
Old 01-26-2005, 10:04 PM
3KSL95's Avatar
3KSL95 3KSL95 is offline
Send a message via AIM to 3KSL95
Re: stock bypass valve?
You have a v8 in a rx7 why, but to answer your question i have no idea, ask yogs or one of the mods they should know good luck with the setup i bet it will haul ass.
1995 3000GT SL (RED)
My mods:
Custom true dual exhaust with x pipe
K&N FIPK
17 inch forged aluminum billet rims from WELD EVO
Old 01-26-2005, 11:58 PM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
the 305 is a fairly popular swap into a RX7, Stock BOV's are good for at least 15psi, not sure what their max is.
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
Old 01-27-2005, 12:41 AM
thanks that should work great! and why a v8 in a rx7? 4.1 more liters to work with than a rotary. more displacement mean i can push a bigger turbo. plus a v8 has a few things rotaries don't. torque, MPG, the ability to survive detonation, etc.............
Old 01-27-2005, 11:11 AM
Igovert500's Avatar
blue + red light magnet
My stock bypass valve started leaking at stock boost (12 psi) around 50k. You can tell it is leaking when you floor it and hear a honking like a goose is under your hood. But you mentioned a low-boost setup, so you should be good.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 01-27-2005, 06:14 PM
Hotshot8792 Hotshot8792 is offline
the 3/S stock bypass valve is crap, if you want a cheap solution but good quality, look into the 1st generation dsm bypass valves. They're made of metal instead of plastic and will hold the pressure.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 01-27-2005, 06:18 PM
that is what i originally wanted to go with but had a extra vr4 one laying around. i will probaly just go with a crushed 1st gen CBV. thanks guys!
