Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 01-26-2005, 08:05 PM
poordudewhowantcar poordudewhowantcar is offline
Send a message via ICQ to poordudewhowantcar Send a message via AIM to poordudewhowantcar Send a message via Yahoo to poordudewhowantcar
Angry any one with honda knowledge HELP ASAP
ok so this car has a splice in it every 6 in. and MY friend and i were doing about 30-ish and pulled the E-brake in his field and the car just shut off and wont start any more!! WTF only the e-lights work. Not even the signals dash highbeams nothing works. so what should a check ecu,fuses,which specific wires? WTF HELP
Old 01-26-2005, 08:08 PM
alphalanos alphalanos is offline
check ur battery terminals. if they are disconnected or somthing. also , dont do stupid shit with your car. sounds like a battery problem.
96 EJ6. Future home of boosted B18C1.
Old 01-26-2005, 08:43 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: any one with honda knowledge HELP ASAP
when you pulled the ebrake, maybe you pulled a wire apart. check the wiring around the ebrake
Team Lonely Drivers
Old 01-26-2005, 08:51 PM
tencent's Avatar
tencent tencent is offline
Send a message via AIM to tencent
what do you mean it has a splice in it every 6in??
Powered By Rice
Old 01-26-2005, 08:53 PM
that means someone just cut that wiring harness up and it looks like shit.
Team Lonely Drivers
Old 01-26-2005, 09:50 PM
tencent's Avatar
get new wires??? having a bunch of splices builds up resistance on the wires causing more heat in the wires and premature failure. This could cause bad stuff like fires... not always bad unless its your car that goes ablaze.. its pretty cool for everyone else though =P
Powered By Rice
