Go Back   Automotive Forums Car Chat > Ford > Mustang > Performance
Performance Discuss Engine, Suspension, Drivetrain, and all other performance modifications here.
Old 01-26-2005, 07:28 PM
CHUCK76's Avatar
CHUCK76 CHUCK76 is offline
Question 5 speed man
will a 1983 mustang gt 5 speed man fit in a 95 mustang
1995 MUSTANG V6 TRANSFORMING TO V8
1989 4X4 GMC
1974 CORVETTE 383 STROKER,GEAR DRIVE,CRANE CAM,DUAL PLANE INTAKE,HEADERS AND SIDE PIPES.
Old 01-26-2005, 10:20 PM
silverstangs's Avatar
silverstangs silverstangs is offline
Send a message via AIM to silverstangs
Re: 5 speed man
Yes
My ride at my site Silverstangs.
Old 01-27-2005, 05:31 PM
CHUCK76's Avatar
Re: Re: 5 speed man
Originally Posted by silverstangs
Yes
thanks
1989 4X4 GMC
Old 01-27-2005, 08:29 PM
StangNut86 StangNut86 is offline
Send a message via AIM to StangNut86 Send a message via Yahoo to StangNut86
Re: Re: 5 speed man
Yes
Ding! wrong!
sorry to walk on you silver, but that's actually not correct... the '95 mustang uses a longer bellhousing for the manual transmission and therefore requires a longer input shaft to work. the '83's input shaft is too short, an dyou'll destroy the trans and clutch if you attempt to run it.
you'd be much much better off finding a t-5 from a '94 or '95 5.0 mustang and installing that. no worries then. i'm sure you can find a junked one with a decent trans if you look hard enough.
-Andy
'89 Mustang 5.0 - How fast? i'll know this weekend.
'86 Mustang LX - Shortblock is built, now for the rest of it.
"Put the subject before the verb, hmm? Fail this class, you will."
-Yoda teaches english class.
Old 01-27-2005, 09:04 PM
Re: Re: Re: 5 speed man
Originally Posted by StangNut86
Ding! wrong!
Yes the 95 is using a longer Bellhousing and longer input shaft, but if he is using the the bell housing that came with the 83 tranny, it will bolt up just fine, and that's what I am assuming he is going to do. He might need to modify the driveshaft and tranny mount. The 83 just brings everything closer. Now if your assuming that he is planning on using a 94/95 bellhousing, then, yes your absolutely correct. He asked if it will bolt in, perhaps I should have asked which bellhousing he was going to use first.
There is also something else I did not say........ the 83 T-5 is not all that strong, and definatly won't live too long under the power of a 94/95 GT engine.
Old 01-28-2005, 12:34 AM
Re: Re: Re: Re: 5 speed man
also true, but the t-5s used in 5.0 applications are virtually identical except for the heavy duty (world class) used in later models. which isn't that much stronger.
i'm thinking if he uses an '83 bellhousing and trans, he'll end up wiht shifter clearance issues that will need to be dealt with, and the shifter will be farther away from the driver's body, never a good thing. maybe a short handle would solve that, or a heavily modified stock one such as mine.
-Andy
Old 01-28-2005, 05:43 PM
CHUCK76's Avatar
yes im looking at using a 302 and trans with the 83 bell.the trans has been replaced and is only a few years old.now does any body know how much shorter the trans will be to get an idea of what kind of shifter mods or fab i'll have to do.the alum. driveshafts in the books show 79-95 mustang so i might have to do some driveshaft mods?
1989 4X4 GMC
Old 01-29-2005, 01:29 AM
Re: 5 speed man
you'll have to cut a part of the trans tunnel out to accomodate the 2 front shifter bolts. you'll need a longer driveshaft, and will probably ahve to make a plate that moves the shifter handle back an inch or so to be comfortable.
the difference in length is less than an inch, i believe.
-Andy
