Old 01-26-2005, 07:26 PM
vinceleto vinceleto is offline
Heater-Thermostat Help
I have a 2000 Caravan with a 3.3 V-6. I have no heat. The blower works, the radiator has fluid and the temp guage barley moves. Can it be anything but the Thermostat?
Thank you,
Vince
Old 01-26-2005, 08:38 PM
Mrbizness1 Mrbizness1 is offline
After the motor has run enough where you think it has warmed up, locate the 2 heater hoses that go through the firewall, one hose goes to the heater core and one is a return, they should both feel about the same temperature. If there is a big difference you could have a blockage in the heater core. If they are both hot then the problem is most likely a stuck blend door. If you are in doubt about the motor not fully warming up you can feel the upper and lower radiator hoses after the motor has run awhile, bot of them should feel hot.
Old 01-26-2005, 10:20 PM
yogi_123rd yogi_123rd is offline
Re: Heater-Thermostat Help
"the temp guage barley moves" = bad thermostat.
The temperature sensor for the gauge is on the engine.
Old 01-27-2005, 03:46 PM
HeadlessHorseman's Avatar
HeadlessHorseman HeadlessHorseman is offline
Send a message via AIM to HeadlessHorseman
Re: Re: Heater-Thermostat Help
Yup.
