Go Back   Automotive Forums Car Chat > Honda > Integra
Old 01-26-2005, 06:39 PM
IntegraRcr96 IntegraRcr96 is offline
Send a message via AIM to IntegraRcr96
Integra GSR oil type
What kind of oil is recommended to be put in a Integra GSR b18C1 engine. Thanks
Old 01-26-2005, 06:49 PM
kornflakes28546's Avatar
kornflakes28546 kornflakes28546 is offline
Re: Integra GSR oil type
10w30... go with the full synthetic
Old 01-26-2005, 07:29 PM
knorwj's Avatar
knorwj knorwj is offline
Send a message via AIM to knorwj
Re: Re: Integra GSR oil type
unless his engine is new, then he will want to run normal 10w-30 in it until it is broken in.
Old:
1993 Acura integra gs-r
New:
1998 chevy BlaZeR2~ AKA "Jeep recovery device"
Newer:
2007 Honda CB900F "919"
Old 01-26-2005, 08:10 PM
One more ?. I have been using 10w40 penzoil and i have been loosing oil. Would this problem be because im not using synthetic oil? Im not burning it. Im not sure where it is going.
Old 01-26-2005, 08:15 PM
Twizted_3KGT's Avatar
Twizted_3KGT Twizted_3KGT is offline
Well if you're sure you're not burning then you better start looking for leaks. Front and rear main seals, oil pan, drain plug, oil filter, valve covers. Just remember nothing leaks upward so where-ever there is oil it's probably from above where it's sitting, not where it is sitting.
Old 01-26-2005, 11:11 PM
knorwj's Avatar
oil never leaks up huh? i've had a few cars that could spray oil from a leaking pan all the way up and coat the hood insulation.
Old:
New:
Newer:
Old 01-27-2005, 01:45 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
How much oil is it loosing? It is normal for a GSR to use some oil.
Old 01-27-2005, 02:13 PM
I add about 4 quarts a month. Not including oil changes.
Old 01-27-2005, 03:01 PM
knorwj's Avatar
4 quarts a month!!!!! holy crap whats the point of changing the oil if you put 4 quarts a month in... but seriously that is way too much oil to loose. You need to have it checked out. because there may be a big problem.
just for reference my integra has 170,000 miles on it and I'll use slightly more than 1 quart every 3000 miles or about 2 months.
Old:
New:
Newer:
Old 01-28-2005, 03:37 PM
whtteg's Avatar
Yes 4 qts is way too much to be loosing. Do you have any oil puddles under the car after it has been sitting for a while? Is there any smoke when you drive the car?
Old 01-29-2005, 05:23 PM
whitGSR07 whitGSR07 is offline
isn't it 5w30 in a GSR until like after 60,000 miles?
Old 01-30-2005, 09:21 PM
whtteg's Avatar
If you live in a warm climate where it never gets cold then you can run 10w-30 other than that yes you want to run 5w-30.
Old 01-31-2005, 02:28 AM
HontegraGSI HontegraGSI is offline
i got a gsr with about 180k on it. what type of oil u think i should use? ive been using mobil 1 synthetic blend (says on label "for engines over 60k miles") I'm way over that!
Old 01-31-2005, 07:09 AM
knorwj's Avatar
Re: Re: Re: Integra GSR oil type
My gs-r says right in the acura owners manual 10w-30 unless you will be in climates below something like -20
Old:
New:
Newer:
Old 01-31-2005, 02:25 PM
whtteg's Avatar
Re: Re: Re: Re: Integra GSR oil type
Yes but the only difference between 5w-30 and 10w-30 is that the viscosity is 5 vs 10 whne the oil is cold. Once the oil warms up (motor warms up) the viscosity is the same between the two oils. 5w-30 oil will not hurt a GSR Actually in my manual it says 5w-30 is perfered.
