Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 01-26-2005, 06:15 PM
1quickneon 1quickneon is offline
Tachometer Problem
Whats up.,
I have an autometer tachometer and i tried to hook it up but had some problems. I hooked the green wire to the blue and grey tach wire in the cluster. The red went to the radio fuse and i tried the back up lights fuse. The white went to the fog lights fuse and the black i hooked to the battery. i had power and the tach would repsond to the rpms but then the needle would go right to 7 grand and wouldnt stay at zero. Then after that i started blowing fuses that i had the red wire hooked up to can anyone help me or does anybody know why its doing that? do i have the wires hooked up wrong? Any help will be appreciated Thankss alot
Old 09-20-2006, 02:34 PM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: Tachometer Problem
If you are hooking up an aftermarket tach, you need to cut the tach wire going to the cluster.
* Mod Statement* I know this post may be old, but I am trying to answer the questions with no replies, to get some useful info out there.
2003 Dodge SRT-4
