Old 01-26-2005, 06:14 PM
mengel1 mengel1 is offline
seat belt light
I just bought a 97 grand am, and the seat belt light stays on constance, I plug in all the seat belts and thats do'nt work, I've unplug the wires under both seats, still on, anyone have any ideas? thanks
Old 01-26-2005, 07:17 PM
Forkliftguy's Avatar
Forkliftguy Forkliftguy is offline
Re: seat belt light
Wires under both seats? Do you have power seats? The only buckle tied into the seat belt warning is the driver's buckle. It is usually a single wire plugged into the bottom of the buckle srap where it bolts into the floor. You can determine if it is just a poor connection in the buckle itself by unpluging that one wire from the base of the belt and ground it out to the chassis. If it is just a poor connection in the buckle, the light will go out once that wire sees ground. If this is the problem, use a good aerosol contact cleaner and spray the inside of the buckle for a few seconds then work the latch plate in and out of the buckle a few times. This will hopefully fix you woes. Good luck.
Marc
MECP Level 1 Installer
Mobile Dynamics Corp. Certified Installer
Clifford Electronics Cetified Mobile Security Installer
Electrician in training
'01 GA SE, Stock....for now.
SudburyGrandz
