Go Back   Automotive Forums Car Chat > Mercury > Villager
Old 01-26-2005, 05:03 PM
racefan2448 racefan2448 is offline
Send a message via Yahoo to racefan2448
94 villager
yes im wondering how hard it is to replace a water pump on my van?i have a repair manual but it dont give much insight on how to fix it.the pulley is loose on it and as far as i can tell it cannot be tightened up any.need some advice on this.
Old 01-27-2005, 04:18 AM
jackass#1's Avatar
jackass#1 jackass#1 is offline
Send a message via Yahoo to jackass#1
Re: 94 villager
never replaced one on a villager yet. but on most other cars the pulley comes off the pump and reused with the new pump. mines a 95 but should be same. ill look at it and let you know something tonight.
Old 01-28-2005, 12:36 PM
dzus dzus is offline
Thumbs down
It's a big pain in the @ss! really tight access. Need to remove all belts(except timing belt),crankshaft and water pump pulleys and lower timing chain cover. Not Fun!
Old 01-29-2005, 03:29 PM
Re: 94 villager
yes it is,i got all the screws off of timing belt cover except for 1 and it is almost behind a pulley and u cant seem to get the pulley off to remove the timing belt cover!!!!!!!!!
Old 02-13-2005, 11:50 AM
Re: 94 villager
i have gotton the upper timing belt cover off,now im having a problem with the lower cover.i only want to loosen the crankshaft pulley so i can get the lower cover off,anyone that can help me with this,it would be helpful.
Old 02-14-2005, 08:26 AM
IH8SPM's Avatar
IH8SPM IH8SPM is offline
Re: 94 villager
If you manage to get to the water pump you might as well change the belt nosense doing all that work twice. I suggest you call a few friends for help physically.
