Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 01-26-2005, 04:52 PM
Leviguy Leviguy is offline
97 Explorer Heater Valve
Any idea where the heater valve on a 97 EXPLORER, v6 is located? The heat will not shut off and I believe the valve may be stuck open. I'd like to locate it so I can check it out. Thanks!
Old 01-27-2005, 03:30 PM
vicv vicv is offline
Re: 97 Explorer Heater Valve
Passenger side, under hood, on the heater hoses going into the firewall.
Old 01-27-2005, 05:40 PM
yotermanic yotermanic is offline
Heat will shut off regardless of heater valve condition. I'd check the blend door.
Old 03-25-2005, 09:14 AM
tonye tonye is offline
Ihave a similar problem the Heater valve is OK, i now have it locked closed... It is vacuum operated, Does any one know how to get at the Inside temp control?
Old 05-14-2005, 07:51 PM
chr97 chr97 is offline
I don't know if this helps but I have a 97 and the heat shut off and would only blow by force,(open window suction or 60 miles) we replaced a black relay under the fuse compartment 5.00 and that didn't work we replaced the blower motor 45.00 by the way it didn't blow while on ac either.
