Go Back   Automotive Forums Car Chat > Nissan > Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs
Old 01-26-2005, 03:01 PM
jmag jmag is offline
SES light code P1447
'97 Pathfinder - service engine soon light on. I went to autozone and they came up with
P1447 - elc system closure valve flow fault
Autozone said they have no idea and that's all they could help.
Any help? thanks
Old 01-26-2005, 05:14 PM
lewisnc100 lewisnc100 is offline
Re: SES light code P1447
That's probably a good thing since they didn't have the code right. P1447 on your pathfinder is a EVAP PURGE FLOW/MON error. Under normal conditions (non-closed throttle), sensor output voltage indicates if pressure drop and purge flow are adequate. If not, a fault is determined.
Possible causes:
- EVAP canister purge volume control valve stuck closed
- EVAP canister purge control valve stuck closed
- EVAP control system pressure sensor
- Loose or disconnected rubber tube
- Blocked rubber tube
- EVAP canister purge control solenoid valve
- Blocked or bent rubber tube to MAP/BARO switch solenoid valve
- Cracked EVAP canister
- Absolute pressure sensor
- MAP/BARO switch solenoid valve
1997 Pathfinder XE
Air Lift Air Bags, Warn Hubs
2000 Windstar SEL
Old 01-26-2005, 06:30 PM
Thanks for the reply. Suggestions to narrow it down? Where is the evap canister?
Old 01-27-2005, 06:02 AM
Re: SES light code read
EVAP canister is behind the rear driver's side wheel.
1997 Pathfinder XE
2000 Windstar SEL
Old 07-23-2006, 02:07 PM
diane cabrera diane cabrera is offline
does anyone know how much it costs to fix this code<
Old 07-24-2006, 07:32 AM
There are a lot of possible EVAP components that can be causing this code, see the list above. It could be as easy as a disconnected hose or multiple EVAP components that need to be cleaned/replaced. You won't be able to get any kind of an estimate until the cause of the error is investigated.
1997 Pathfinder XE
2000 Windstar SEL
Old 07-24-2006, 09:07 AM
thanks for the help!!!
