Old 01-26-2005, 02:53 PM
bighauns's Avatar
bighauns bighauns is offline
Send a message via MSN to bighauns
Bigger Stock Turbo On JDM 4G63T??
Hey guys!
Quick Question...
I am getting my car back today after a while and I took a look at the turbo on it. It is bigger, but I don't know what it is. The intake looks bigger on it and the compressor wheel has larger blades.
Is this a stock turbo or did this guy put a new one on it or what?
Any help would be neat, as well I am not sure if you need any more info, if so just let me know.
Thanks!!
"You can have everything in life you want if you will just help enough other people get what they want."
Old 01-26-2005, 04:12 PM
97GSTspyder's Avatar
97GSTspyder 97GSTspyder is offline
Send a message via AIM to 97GSTspyder
Re: Bigger Stock Turbo On JDM 4G63T??
i think the JDM motors come with a TD04HL housing and it's really a small 16g? i think. i'm not 100% positive, but i've read shit about those JDM 4g63T motors before.
Old 01-26-2005, 04:18 PM
ITSME4G63 ITSME4G63 is offline
Send a message via Yahoo to ITSME4G63
if you were lucky, your jdm motor came with 510cc yellow top injectors and a big 16 turbo.
Old 01-26-2005, 04:39 PM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
Actually the turbo that comes on the JDM motors resembles a 15g. It has a 13g compressor housing with a small 16g compressor wheel.
I hope that mechanic used your stock intake manifold or got the computer for the JDM mani.
Old 01-26-2005, 08:11 PM
bighauns's Avatar
Re: Re: Bigger Stock Turbo On JDM 4G63T??
so, is this better than the US 4G63T ones? Is there a chance that is came with 510cc injectors and a 16g, or no??
What happens if he didnt use the stock intake manifold or the computer from the JDM one??
Old 01-27-2005, 02:17 AM
EclipseRST's Avatar
Banned
If it says TD04 on the turbo housing its not a 16g... If it says TD05H the turbo could be a 14b or 16g. You will have to take off the intake pipe to see what it is.
Another thing, check the color of the injectors, if they are yellow then they are most likely 510's. If they are blue or black then they are probably 450's.
About the intake mani... you car probably would run like shit if it was the JDM manifold without the computer, or it probably just wouldnt run at all. I'm guessing he used your stock mani.
Old 01-27-2005, 11:42 AM
bighauns's Avatar
okay, so it will be obvious if there is an issue then eh? i will take a closer look at the turbo and maybe snap some picuters soon. thanks for the help Jake.
EDIT--> I spoke with my mechanic and he said that the injectors were yellow. So i guess that means they are the 510cc ones...YAAAY. Yes, he said that he used the stock intake manifold, so that is a plus :-) As well, how will I know when I take off the pipe which turbo it will be? If it says TD04, what will it be then?
Old 01-28-2005, 06:47 PM
bighauns's Avatar
jake, i am bumping this so i get an answer from you...or anyone who knows.
thanks
Old 01-28-2005, 07:19 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Then it would most likely be a 13g.
Old 01-29-2005, 12:45 AM
bighauns's Avatar
Okay, i looked...it has TD05H on it, but it is not the same as my old turbo. What does this mean? and how does this compare to the stock USDM one?
Thanks.
Old 01-29-2005, 01:54 AM
EclipseRST's Avatar
Banned
Take the intake pipe off and see which compressor wheel it looks like. Does it look like pic #1 or #2?
Old 01-29-2005, 10:39 AM
bighauns's Avatar
Pretty sure it looks like the second one.
Old 01-29-2005, 04:59 PM
2of9 2of9 is offline
if its the yellow injectors, shouldnt it come with the big 16g turbo? Any ways, what kinda 4g63T is off from, the Evos? or just a typical USDM 4g63T with lower miles and with modded injectors?
"i told you it was third, I lengthen the injector pulse another millisec and tuned the NOS timer, and you'll run nines"
--2OF9--
(DSM team specialist) ;D
#808/1000
Old 01-29-2005, 06:02 PM
1g90gsx's Avatar
1g90gsx 1g90gsx is offline
evo 3 4g63t
yellow top 510's
td05 16g
bronze valve cover
red top galant 4g63t
cyclone intake manifold
red top valve cover
pretty much the same as the one here except for one thing i found, the rods are bigger and the wrist pin is also bigger dont remember the mm size.
my friends shop has an evo 3 on the floor going in the mirage.
1990 MIRAGE HB
4G SWAP
FMIC
ACT 2100
TIAL BOV
TIAL WASTEGATE
FIC 650"s
SX AFR
MAFT
INNOVATIVE DUEL BB TURBO
TURBONETICS MANIFOLD
255 PUMP
WISECO 8:51
EAGLE RODS
DELTA 272 CAMS
SETRAB OIL COOLER
AEROMOTIVE STARLITE HOSE
AUTOMETER
ROTA CIRCUT 8"S
Old 01-31-2005, 07:56 PM
bighauns's Avatar
Not sure if that answers my question directly or not. I am not sure what the engine is out of, but it is a red top. Not sure if it is the cyclone or not. It is JDM not USDM.
Jake, or anyone, could you let me know what that turbo is in the second picture up above?
