climate control
Help......cant get the heater/defroster/a/c/vent even rear defrost to work none of the buttons on the module do anything.....should i replace that or start somewhere else......
thanks for the help in advance Paul |
Re: climate control
If you can't select, or if the blower is running but there doesn't seem to be any air coming out, there is a problem with blockage in the heat/evap core, or the blend door is stuck and directing air to several places all at once, so no strong flow comes from any one position. Sometimes a vacuum leak can cause this, look under the hood and dash for any vacuum lines that are damaged or pulled off.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made... ...empty gun rack. |
Re: climate control
OH! Check your fuses too.
Re: climate control
I was going to suggest fuses too, because mine blows that circuit all the time. When the fuse blows, the vents just get stuck in the last position you had it in before the fuse blew, and the rear defrost just simply won't work.
