Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 01-26-2005, 02:07 PM
MyTOY's Avatar
MyTOY MyTOY is offline
Squeaky Wheels?
97 SIERRA 5.0 4X4
There is a squeaking I hear when I'm driving slow that sounds
just like squeaking brakes but it's not when I'm applying the
brakes. Could this be wheel bearings? I haven't messed with
wheel bearings in a long time. Let me know if you need more
info and I'll see what I can do. Thanks!
Old 01-26-2005, 08:27 PM
planedude planedude is offline
Re: Squeaky Wheels?
If you just touch the brakes when it happens does the sound go away?
Old 01-27-2005, 10:43 AM
MyTOY's Avatar
Re: Squeaky Wheels?
I just tried to check it out and it seems
that the sound does not go away when
braking. The sound is random.
Squeeek........Squeek..Squeeeek..............Squee eeek
Old 01-27-2005, 10:46 AM
MyTOY's Avatar
Re: Squeaky Wheels?
If you meant ONLY Just touching the brakes but not
really braking, I think I'll have to look again. Thanks
Old 01-27-2005, 12:50 PM
2000CAYukon 2000CAYukon is offline
Re: Squeaky Wheels?
The wheel bearings are sealed so I doubt that is your problem. The brakes have a warning sensor that will squeeze when the brakes are worn.
Time to pull the wheels and see if the brake wear sensor is touching the rotors.
//2000CAYukon
Old 01-27-2005, 06:40 PM
sudsy49 sudsy49 is offline
sqeaky wheels
sounds like it could be one of the u-joints, most likely the front one! I had to replace my front one at 30,000 miles, on my 2000 Sierra.
Old 01-30-2005, 08:29 PM
SigGMC96 SigGMC96 is offline
Do you have chrome rings around your wheels? I had the same problem, pulled off the factory wheel dress-up rings and it went away.
Old 01-30-2005, 11:50 PM
steve in alaska steve in alaska is offline
agree that it's time to look at the pads.I had the same thing happen one time, intermittent squeak..and it was a pebble caught between the rotor and rotor shield..pebble kept moving around so it wasn't always there! Drove me nuts!
Hope your problem is easily solved like mine was, and with no expense!
Old 01-31-2005, 10:16 AM
MyTOY's Avatar
Re: Squeaky Wheels?
Thanks guys. I'll take off the wheels & check it out.
No, I don't have the wheels w/ the rings, But thanks.
Old 01-31-2005, 08:04 PM
WEF WEF is offline
If it goes away when you actually apply the brakes, it's the wear indicator. You need new pads. Usually, it is first noticed around corners going slowly.
Old 02-02-2005, 07:18 PM
blabhern's Avatar
blabhern blabhern is offline
Send a message via AIM to blabhern
Re: Squeaky Wheels?
I would venture to guess one or both of your brake rotors are out of round. Get them turned and ask the shop to check for flatness. If so they are pretty cheap at Autozone. I think they're around $30.00. I just did this on my 96 for the same reason. It cured the squeaking
Old 02-04-2005, 10:47 AM
MyTOY's Avatar
OK, It's stating to sound like I need a brake job. I will have
to hope it holds for a couple weeks till I can have them looked
at. I don't know if it's a related prob., but when I come to a stop
and the truck "settles" back, there is a clunk and when I let go
of the brakes to go, there is a clunk and like a "settling" in the back.
Old 03-23-2005, 09:33 AM
MyTOY's Avatar
Re: Squeaky Wheels?
Rotors it was - brakes were fine.
The rotors were a total mess.
Thanks
Old 04-06-2005, 12:36 PM
MyTOY's Avatar
No, still squeaking! But differently. I took it to a shop when I
thought my brakes were bad. They replaced rotors up front
and wheel cylinders in back. They said all brakes were plenty
good. The squeak is reallt noticeable and loud in reverse. Today
I will lift it and spin the wheels & make sure it's lubed. After that, I
will have to take it back to the shop and have them look at it.
Old 04-08-2005, 09:21 PM
blabhern's Avatar
Re: Squeaky Wheels?
Here's another suggestion. I have a 94 Grand Am that had the issue of settling in the back then clunking when released. It ended up being a bad shock, yes a shock. Just something to look at. It took me a couple of days of messing with the brake components before I found the real issue. Good luck and sorry the rotors didn't fix your problem.
