Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 01-26-2005, 01:48 PM
kcr827 kcr827 is offline
replacing rear speakers for a 4runner
Does anyone know just how to replace the 2 rear door speakers on a 98 4runner?
Old 01-27-2005, 05:38 PM
AlienEvolution's Avatar
AlienEvolution AlienEvolution is offline
Send a message via ICQ to AlienEvolution Send a message via AIM to AlienEvolution Send a message via MSN to AlienEvolution Send a message via Yahoo to AlienEvolution
Re: replacing rear speakers for a 4runner
Speakers really arent hard to install/replace, if the wires to the door and everything are in tact, you just need to take off the covers on the inside, pull the speaker out, then cut the wires and solder them directly (seems to work better for me) to the new speaker.
Shouldnt be too tricky, and make sure you buy the right kind of solder.
"I have a Tundra '01 with 245k miles. Yes 245,000 miles. and only had to replace a lightbulb. This truck is bulletproof."
-ryba1000
Wurd.
Old 02-01-2005, 11:48 PM
Mrbikerman Mrbikerman is offline
Send a message via AIM to Mrbikerman
There are these little clip things that you have to push in on the center of them and pull out. Then theres a screw inside the door opener, unscrew and slide it towards the front of the car. Then pry off the handle that you use to shut the door, it goes upward. Then there are a couple screws inside of that, and the rest is popping clips out. Its real easy, but if you are trying to send a lot of power to your speakers, yoll have to get an amp and replace those stock wires. That is a little more complicated
