Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 01-26-2005, 12:33 PM
redneck_cadillac01 redneck_cadillac01 is offline
Question 91 Dodge Shifting In Morning
My 91 Ram 4x4 Shifts Fine Like There Is No Problem. The Only Thing That Is Bothering Me Is In The Morning. First Thing In The Morning, It Stays In One Gear For To Long. However, Once I Shift All The Way Thru The Gears, It Stops Doing It Untill The Next Morning. I Replaced The Filter And Fluid About A Month Ago So Im Not Worried About That. But What Could Be The Problem?
"Watch where your goin', remember where ya been...thats the way I see it- I'm a Simple Man."
Old 01-26-2005, 10:54 PM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
Re: 91 Dodge Shifting In Morning
Where do you live? I know it's cold where I live, and transmissions will hold gears for longer when it's deadly cold outside...
My Mopars
Old 01-26-2005, 10:56 PM
mxracer111 mxracer111 is offline
where are you located, i know here in ny for example its gonna be 25 below with wind chill. just woundering if the cold is making the fluid thick and not allowing the clutch to work till it warms up
Old 01-27-2005, 06:53 AM
Yeah, I live in Maryland and it has been pretty cold here. So im sure that is what it is. Still, i hate hearing the truck rev that loud and long in any given gear, is there anything I can do to help with this problem?
Old 01-27-2005, 08:48 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
1991, so you've got the 727 or 904, right? Mine always did the same when it was cold, never hurt it. Get up to about 10-15 mph (or a little higher) and let off the gas and let it shift. If it won't shift, add a few mph and try again. Eventually you'll get the speed that will let it go into the next gear; you can do the same for the 2-3 shift also. If you stay on the gas, it WILL be in the lower gear quite a bit longer than usual until it warms up.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 01-27-2005, 10:30 PM
2000mudder's Avatar
2000mudder 2000mudder is offline
91 has a 999 trans. its a comb of the 727 & 909 with a od. have the same trk and mine dose the same thing here in ohio. -5 degr last week and i never got heat after 1 hour
Old 01-28-2005, 07:42 AM
Whups, thanks 2000 for straightening me out on the trans; I forgot about the bolt-on OD unit; they start in '91?
Old 01-28-2005, 08:18 AM
Thanks Everyone For All The Info. Guess I'll Just Have To Wait 'till It Warms Up A Bit. No Big Deal, Just Wondering If It Was A Problem I Should Jump On Top Of Ya Know? Thanks Agian.
Old 01-28-2005, 09:59 PM
troy1 troy1 is offline
AF -Advisor
dodge has problem with a over cut seal groove when the seals get old and hard they shrink which causes a delyed shift. I think it is 2nd to 3rd shift.
