Go Back   Automotive Forums Car Chat > Honda > Del Sol
Old 01-26-2005, 10:20 AM
darksol06 darksol06 is offline
taking off cat? good or bad idea
sorry another exhaust question. but my friend said if i take off my cat it sounds real good with the apexi n1 muffler is this true or not. will it be real ricey. thanks again for the help
Old 01-26-2005, 10:36 AM
94SolGrl's Avatar
94SolGrl 94SolGrl is offline
Honda GODDESS/Global Mod
Send a message via AIM to 94SolGrl Send a message via MSN to 94SolGrl
Re: taking off cat? good or bad idea
First off, it's illegal. No shop will do it. Put just the muffler on. Should be enough noise for you. If it's not, remove the resonator. If that's not loud enough, you're deaf.
~*Emily*~
1995 Nissan 240SX - S15 whore
HOW TO POST PICS!
Old 01-26-2005, 03:55 PM
i thought it was illegal but i wasnt sure. thanks for the help.
Old 01-26-2005, 05:40 PM
Plastic_Fork's Avatar
Plastic_Fork Plastic_Fork is offline
A high flow catalytic converter is probably the answer you're looking for. They don't cost too much, flow better and have just a slight kick in noise, but aren't illegal.
A removed cat is illegal where they check emissions and can make it quite a bit louder. Friend of mine put a straight pipe in place of his cat on his Integra LS and it was noticeably louder - he already had a muffler and header. He put his cat back on. I would have too.
1995 Honda CRX del Sol VTEC
Manufactured: Suzuka, Japan
Production Sequence #1269
Team Del Sol member #1131
HondaVision: Team Sol Forum - Home of Team Del Sol
Old 01-26-2005, 08:04 PM
Ace$nyper's Avatar
Ace$nyper Ace$nyper is offline
Banned
Send a message via AIM to Ace$nyper Send a message via MSN to Ace$nyper Send a message via Yahoo to Ace$nyper
Re: Re: taking off cat? good or bad idea
LMFAO
yea and shops will do it well in some areas where there is no smog testing
but dont do it a honda cat flows very well but if you feel its not enough get a catco one.
Old 01-26-2005, 09:45 PM
Privatebigandrew's Avatar
Privatebigandrew Privatebigandrew is offline
Send a message via AIM to Privatebigandrew Send a message via Yahoo to Privatebigandrew
Never say never, none, or any other absolute. There is always an opposite. Its like those true or false questions. Anyhow to the point. The shop that did my custom exhaust actually asked me if i wanted to take my cat off. Thats in south carolina though, but it is a "shop" and they would do it.
94' Del Sol VTEC (B16A3) SOLD.
Accel plug wires, NGK iridium IX plugs, AEM short ram intake, DC sports ceramic coated header (4-2-1), Airmass high flow cat ,Custom Magnaflow exhaust, Bosal Brospeed tips, Neuspeed short throw shifter, Tokico clutch master cylinder, Tokico clutch slave cylinder, Prothane complete kit bushings, Brembo front rotors, NR EL-Glo instrument gauges, CTR LSD trans with ITR final drive, Exedy chromoly flywheel, ACT HDSS clutch kit, Raxle axles.
