Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 01-25-2005, 10:38 PM
Volkswagon Volkswagon is offline
fuel sender and ecm reset/calibration?
how much do they charge to do this? I may need to have this done after completly changing my Fuel pump/sender assembly. It still does not work correctly.
Old 01-25-2005, 11:20 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: fuel sender and ecm reset?
did you purchase a new fuel pump with sending unit or did you pick up a used one?
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 01-26-2005, 12:23 AM
Used fuel pump assembly but was it tested on the bench. I transferred the new sending unit from the previous fix attempt onto this assembly.
At the begining it was the gas gauge that was not reading accuratly. So I replaced the sending unit and the gauge worked fine, but now the fuel pump does not work when the engine is hot, I jumpered the hot lead to the pump and the pump starts, only when its cool, when its hot jumpering will not energize the pump??? why?
I tested this recent installation by letting the car run till it gets hot. I finally am able to duplicate the problem, and I jumper it with a hot lead, the pump did not come on and I was giving it 12 volts!
Does the ecm not allow the fuel pump to ground so even if I give it 12 volts the pump will not energize.
After the car cools,it starts right up. And I can hear the fuel pump wirr up like it supposed to. When its hot, it does not make that sound.
Do u think I have a fuel pressure regulator problem?
Old 01-26-2005, 10:33 AM
bump
Old 01-26-2005, 10:42 AM
Isuzu Guy
http://www.geocities.com/endre_rl/isuzufaq.htm#faq22
It might be. Looks like the part costs about 50 bucks from Isuzu. Might be worth a shot.
-Ryan
Isuzu Moderator
Car Show Tips
Old 01-26-2005, 02:15 PM
I think its a loose wire honestly, where is the ground for this thing?
Old 01-26-2005, 02:26 PM
Isuzu Guy
Thanks to SOLSTER for the image (which won't be up much longer)
http://www.icess.ucsb.edu/~greg/rode...al/manual2.gif
It is a bit blurry but in the center of the photo it shows the ground listed as under the center consel.
good luck!
-Ryan
-Ryan
Isuzu Moderator
Car Show Tips
Old 01-26-2005, 03:11 PM
So you remove the center consol? I have an automatic.
Old 01-26-2005, 03:21 PM
Isuzu Guy
yup. lift up the arm rest and there are 1 or 2 screws in the bottom of the compartment that attaches the back half of the consel.
-Ryan
Isuzu Moderator
Car Show Tips
Old 01-27-2005, 08:07 AM
Well that looks ok, I put everything back together and the car so far has started without incident, Although I don't hear the pump spinning up everytime I turn the key to the "on" position.
Now I get a CEL conditon that I will have to check out. Maybe all the connections are working now?
PS seems making sure the wiring makes good contact helps a lot.
Old 01-27-2005, 08:10 AM
Bigpoppax2 Bigpoppax2 is offline
The dealer cost of a reset of the ecm for purposes of fixing the installed fuel sending unit is just under 100 bucks. I still can't see why this is necessary, but some have had to do it.
Joe
Old 01-27-2005, 08:14 AM
It seems ok, now I need to see about that CEL?
Old 01-27-2005, 08:24 AM
That's normal to not hear the pump run every time you turn the key to the one position. You will only hear it if the pressure in the lines has dropped to the point it needs to pressurize them again.
Like it's been off for a while or sat overnight....
Joe
Old 01-27-2005, 12:56 PM
The error I get is P 0452 EVAP control system PSI low, or small leak detected? will this go away? It seems it will not interfere with the vehicle performance...
How do you reset this SUV? neg terminal off for a few minutes? I had them both disconnected for quite a while and that did not seem to clear it, I'll try again.
Old 01-27-2005, 12:58 PM
Thanks again Joe seems all is good, except for that cel thing ^^^
