Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-25-2005, 09:11 PM
apmanzojr apmanzojr is offline
Send a message via Yahoo to apmanzojr
Need Help 92 Eagle Talon 1.8 check engine
Hi,
I have a 92 Eagle Talon 1.8 non turbo 4 cyl manual. The check engine light went off today while starting my car and I'm having a problem of starting it at first but I was able to start it but the check engine light does not turn off and somebody told me that I have to get an code reader in order for me to know what is wrong with my car. But the problem that I have is I don't know which code reader to get I know some code reader are compatible only for the year 96 and newer and I don't know which code reader to get that is compatible with my car. I went to Kragen auto and Autozone and ask those people there but they don't know either so any suggestions?
Thanks.
Old 01-27-2005, 09:15 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: Need Help 92 Eagle Talon 1.8 check engine
you can read the codes with a analog voltmeter. check the faq thread or search the forum for "how to read 1G*codes"
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 01-28-2005, 07:42 AM
RSLaser RSLaser is offline
I posted this along time ago to help with these types of Q's....so here it is again:
You can find alot of "what if" answers by doing a SIMPLE diagnostic check.
And every newb asks the same question over and over about idling and surging...check your diagnostics.
Follow these steps:
WITH THE KEY OFF
1. Look under the dash on the driver side.
2. There is a vertical plug, sometimes with a cover, thats rectangle (this is the Data Link Connector).
3. Looking at the plug youll notice that there are only a few terminals. Now using an voltmeter connect the pos to the TOP LEFT (OBD OUTPT), and the ground to the BOTTOM RIGHT (Ground).
4. Turn the key into the on Position. It will give you a read out it passes. Either Long or short jumps with the needle.
Record your findings then check the code.
It always reads Long jumps then short jumps, and it will repeat over and over.
CODES and Problem
1.8L
LS -02 Sensor
LSS -Air flow sensor
LSSS -Intake air temp sensor
LSSSS -TPS
LSSSSS -Motor position sensor.
LLS -Engine coolant temp sensor
LLSS -Crank angle sensor
LLSSS -No. 1 cylinder TDC sensor
LLSSSS -Speed sensor
LLSSSSS -Barometric Pressure sensor
LLLSSSSSS -Ignition timing adjustment signal
LLLLS -Injector
LLLLSS -Fuel Pump
LLLLSSS -EGR <California>
SSSSSSSS -Normal
2.0L
LS -02 Sensor
LSSSS -TPS
LLLS -Detonation Sensor <Turbo>
LLLLS -Injector
LLLLSS -Fuel Pump
LLLLSSSS -Ignition Coil
SSSSSSSS -Normal
Info From Chilton Manual.
Try it anyway, you never know what could be wrong.
1991 Plymouth Laser RS
Only sat for a few years....
