Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Exterior and Wheels
Exterior and Wheels This is the place for all exterior wheel modifcations.
Old 01-25-2005, 06:29 PM
seco seco is offline
Banned
Tints removal?
Does anyone now how to remove tints without messing up the defrost wires?
Old 02-04-2005, 01:32 PM
blue94eagletalon blue94eagletalon is offline
Re: Tints removal?
i am having the same problem too. Im "thinking" of trying to peel it off and using rubbibg alcohol to get the adhesive off but i dont know for sure.good luck. if it works ill let you know
Old 02-04-2005, 04:09 PM
imtheoneandonlyD's Avatar
imtheoneandonlyD imtheoneandonlyD is offline
Send a message via AIM to imtheoneandonlyD
Re: Tints removal?
could try heating it up to remove it.
Pictures of the Truck
Old 02-04-2005, 06:01 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: Tints removal?
razerblade & glass cleaner. you would be supprised how stong that tint is!! peal one corner (make sure to get both layers) and pull. it took me about 15mins to do my 4door elantra. shit is stong. i had to yank it preatty damn hard at times for it to come off.
after you get that stuff off use the glass cleaner and razerblades to get any left over glue off. i was worried about that when i started, but after the front windows i knew i had nothing to worry about. it comes off preatty well, dosnt splinter.
DSM geek
Old 02-04-2005, 07:20 PM
bighauns's Avatar
bighauns bighauns is offline
Send a message via MSN to bighauns
Re: Tints removal?
I have done my share of tinting. Just get a corner and rip it as fast as you can in the largest chunk possible. Then you take cleaner (preferably some sort of glue remover if you can get it) and steel wool and just steel wool the shit out of it. It will not wreck the the defrost wires. It can be kinda messy, so lay down some newspaper in the trunk and just get comfortable.
"You can have everything in life you want if you will just help enough other people get what they want."
Old 02-07-2005, 03:27 PM
Banned
i think id rether pay someone to do it 4 me it cost like 50 bux
Old 02-07-2005, 05:58 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: Tints removal?
just get a hair dryer, glass cleaner and a razor blade. pick a corner and peel the edge loose with the blade then peel it back heating it up with the hair dryer as you go. once you get it all peeled off clean the window a couple times to get rid of the glue.
most of it dissolves with plain old window cleaner.
DONT USE STEEL WOOL if will scrath the window and possibley take the coating off the defroster wires. and its overkill anyway
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 02-08-2005, 07:57 AM
1Fast_Tsi's Avatar
1Fast_Tsi 1Fast_Tsi is offline
the best way is to get a black hefty bag and cut it open, then place it on the window get a hair dryer and heat the back up, once you see the bag has sealed to the window tint just peel off and all of the glue and tint will come right off without a problem.
Red 90 tsi AWD 5speed
Love KIllin those V8's!!!!!!
Check me out at www.cardomain.com/id/1fast_tsi
Old 02-08-2005, 03:03 PM
bighauns's Avatar
Re: Tints removal?
Steel Wool will not scratch the windows at all. I guarantee it. Just use the glue remover and you are set. I have done quite a few windows this way and you are okay. There are tonnes of shops that do this. My back window looks totally perfectly new, it doesnt scratch it nor will it wreck the defrost lines.
HOWEVER
If that works, that sounds totally brilliant. I am going to have to try that. All I am saying is that Steel Wool will not wreck it.
Old 02-08-2005, 03:04 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: Tints removal?
another good glue remover is glass cleaner with Ammonia. spray it on and let it sit for about 30 seconds and it just wipes off.
95 Talon TSI AWD
97 Eclipse GST
Old 03-15-2005, 01:20 PM
DCHomeBrew DCHomeBrew is offline
Re: Tints removal?
Spray the window down with glass cleaner( Windex w/amonia works best), cover with black plastic bag and set in sun for a couple of minutes, pull on corner of tint with even steady preasure and tint should just peel off without leaving glue.
'91 Chrysler LeBaron 3.0 Auto (soon to have body kit)
'91 Plymouth Laser 2.0nt 5spd (need tranny $750, you guessed it, goin' in colt)
'87 Honda CRX (soon to be conversion)
'86 Dodge Colt Vista 4WD (gonna have 4g63)
