Go Back   Automotive Forums Car Chat > Honda > N2O | Turbo | Superchargers
N2O | Turbo | Superchargers Tech forum to assist in Honda/Acura Performance.
Old 01-25-2005, 06:23 PM
ChumleyEX's Avatar
ChumleyEX ChumleyEX is offline
Send a message via AIM to ChumleyEX
Supercharge a motor with 156000 miles
Hi I just bought a jackson racing supercharger for my 98 civic EX. I have the D16y8 motor with 156000 miles on it. I am good to the car, it doesn't smoke or anything. Do you all think it's ok to supercharge it or do I need to buy a new motor. If I need another motor any good idea where to buy a stout rebuilt one. Thanks
And Knowing is half the Battle
Old 01-25-2005, 06:47 PM
turboEKhatch turboEKhatch is offline
Re: Supercharge a motor with 156000 miles
Compression check + leakdown check. If you have good compression and zero/low leakdown you're fine, it doesn't matter how many miles are on it.
Old 01-25-2005, 07:13 PM
ChumleyEX's Avatar
Compression + leak test?
Old 01-25-2005, 07:15 PM
Leakdown, not leak. If you do a compression check and everything is gravy you dont really need to do a leakdown test. Go to sears and buy a craftsman compression tester, it should have instructions on how to use it. It measures the cranking compression of your motor, which is a good indication of ring seal and other things.
Old 01-25-2005, 08:27 PM
ChumleyEX's Avatar
Thank you very much
Old 01-26-2005, 06:36 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
the compression may give you a general idea, but, if your results are iffy with the compression, try the leakdown along with it.
the jrsc is a detonating machine. though, it is not an immediate threat, unless you are in high boost levels, it will however wreck havoc on your pistons and ringlands overtime. if your motor health is good, just remember to control detonation when you put the blower in.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 01-27-2005, 08:01 AM
big bad mohawk guy's Avatar
big bad mohawk guy big bad mohawk guy is offline
Go Turbo!!!!!!!!!!!!
1988 crx hf
cool air intake
#1 racing exhaust
sprint spings
B&M SHORT SHIFTER
gutted cat.
