2000 Silverado loses electric when I try to start
Hi,
This is my first post and I really need help. Here is my problem. I drove my truck home, no problems. 1 hour later went to go, turned key to start ,heard a click and all electrical went out, totally dead. I pulled of the negative cable, apparently something reset because all electrical came back. Turned key to start, click and no jucie anywhere. When there is jucie, it is strong, headlights are bright, horn works. It looks completely normal. I can take the key to ignition with no problem, but hit start and all elecrical is gone. Any suggestions. Thanks! Bill |
Re: 2000 Silverado loses electric when I try to start
Check your fuses.
'04 Silverado 1500 4x4 5.3L 3.73 G80 |
I checked all the fuses. None bad. Also, when I disconnect the negative for 60 secs and reconnect, all power comes back until I hit the starter.
umm
well iam a hater of electrical prob's but here's a thought i'd look at the ignition switch or the engine ground
-i love paintball -i love datsun z cars -oh i love my HARLEY! -class A mechanic -heavy eqipment mechanic -equipment operator -mig,tig,arc welder -lemon silverado owner -pistonslap.com |
Chech For Loose Battery Connection Or Battery Corrsion
To Test: Turn On Light Then Try To Start If The Light Go Dim Or Out Then Come Back On After The Key Returns To Off It Could Be Loose At Battery |
what is the voltage at the battery? Take BOTH the terminals off and clean them....and the ground at the frame. Check all positive connections if possible, not real sure how the new trucks are wired couldn't be that much different than my 88 & 96.
Matthew Brough ![]() 1997 Geo Prizm -- 301,000 miles 2000 Honda Accord -- 225,000 miles 2004 GMC Yukon XL -- 223,000 miles 1987 Jeep Comanche -- 116,000 miles |
If you can get it to Advance Auto or another parts store, they can analyze the battery and charging system for free. I've had several vehicles that would not start due to a weak battery, even though lights, etc worked.
It's Fixed
For anyone who is interested. The problem was a loose positive terminal. I had the battery replaced at AutoZone this summer and the dude must not have tightened the terminal well enough. Very wierd how this problem manifested itself.
Thanks for yall's help. Bill |
