Old 01-25-2005, 05:47 PM
bh04's Avatar
bh04 bh04 is offline
Send a message via MSN to bh04 Send a message via Yahoo to bh04
Underdrive pulley
What would an underdrive pulley do for my car if I were to put one on? 2000 2.2 2 door automatic
Old 01-25-2005, 05:59 PM
noshun's Avatar
noshun noshun is offline
Re: Underdrive pulley
it has a smaller diam and there for 'underdrives' the accessories. It stops them from robbing as much power from your enging. It also weighs less so requires less power to spin as it has less inertia, something the reduced Diam has something to do with too.
They can have negative effects though!
underpowered elctricals, lights getting brighter as revs rise, not enough juice for 'em at idle. Also your waterpump wont spinn as fast. That explains it's own downside! Ac (if equipped) wont work as good!
Red Z24 = Dead, 03 2 door = 15.5 with no traction. low 15's here i come
'Never forget Grasshopper, Not speed, smile!'
Old 01-25-2005, 06:04 PM
bh04's Avatar
hey, thanks for the reply. This is off this subject but i recently just got some new rims. They are 18 X 7.5, would it be better to get bigger brakes (rotors, pads, etc.)
Old 01-25-2005, 06:11 PM
noshun's Avatar
Re: Re: Underdrive pulley
It depends. Brake upgrades aren't cheap.
www.rsmracing.com
if you hate the look of the teeny 10" stock brakes and rear drums behind your nice big wheels then do it!! Also it's a good idea if you intend to modd it for performance. But beware. The larger your wheels and brakes and anything unsprungs the handling can deteriorate and also you will get less power at the wheels. If you increase the diams of these components then you increase their inertia. They will require more effort (hp) to turn! Just a little info!
Old 01-25-2005, 06:18 PM
bh04's Avatar
when they are put on, and i decide not to change the brake size and stuff, will it hurt the brake rotors, pads, calipers etc. and eventually go out and break
Old 01-25-2005, 06:19 PM
bh04's Avatar
also, should i change the break lines as well, sorry for the extra post
Old 01-26-2005, 07:31 PM
noshun's Avatar
no it won't but make sure they're up to scratch when you're there.
The hoses. I would upgrade to s/stell braided just because they will last longer but if you upgrade the caliper then I'd change the hoses anyhow
Old 01-26-2005, 10:37 PM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
Ah hem.... time to clean up this post..
No one makes an " underdrive pully " for the 2.2 2200 engine...Ligtened yes... Only thing close to an under drive is Cavalier connections " power pullys" Thier crank pully is smaller yes but the alternator is larger to make up for the difference. Reason why the 2.2 non ecotec can't have them is because slowing down the belt would cause loss in the water pump efficency and might lead to overheating problems. On the 2.4 the water pump is on the drive chain and seperate from the belt..
carry on....
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Old 01-27-2005, 09:47 PM
Nitrous_Boy Nitrous_Boy is offline
Banned
Send a message via Yahoo to Nitrous_Boy
there is a company that sells underdrive pulleys for 2.2 and there is only one. i will try to figure it out and post it on here.
Old 01-27-2005, 09:49 PM
Banned
he is right though about the water pump. alot of people try using a higher output fan or a different radiator. just some suggestions. i look into getting a pulley for my 2.2 but i am unsure still. i will try that cavalier connections through CRJ but what is the website
Old 01-27-2005, 10:15 PM
Lifted GMT-360!
www.cavalierconnection.com
If you knew someone with a CNC milling machine you could have one made. I'd like to see a link to this business that you says makes them... the Cavalier connection belt is actually shorten 2 inches.. which isn't too bad to keep the pump moving fluid properly..But i think you just have them confused with a 2.4 or they mislabled it..
Old 01-28-2005, 05:11 PM
Banned
naw i helped a guy put one a 2.2. they look different i'll have to call my buddy lee for the company name
Old 01-28-2005, 09:43 PM
noshun's Avatar
I have nothing to add. Hmm I MUST be tired!
Old 01-29-2005, 10:38 AM
Lifted GMT-360!
i am still skeptical... i want to see some hard evidence before i belive this. Pics of the stock crank pully next to the "underdrive". Or the link..
Old 01-29-2005, 10:53 AM
Banned
easy killer what they say on it is that you have to upgrade you cooling before installing. like radiator or fan.
