Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-25-2005, 05:16 PM
sonoflarry sonoflarry is offline
95 Mustang Engine tapping noise
95 Mustang 3.8 V6. New purchase. 80,000 miles. I recently noticed an engine tapping noise but only under certain circumstances. No noise when engine is in idle or general driving conditions. But I hear the metal tapping noise when in park and rev up the engine or if I accelerate fast after a stop sign and get the engine up to 2500 to 3000 rpm before it shifts. No noise below 2500 rpm. I decided to flush the engine and change the oil. When I turned the car on after this, the engine made that tapping noise but only for two seconds until the new oil had a chance to recirculate. What's the problem, bearing? rods? rockers? valves? I don't think its injectors or converter noise. What is the best way to isolate where the noise is coming from?
Thanks
Old 01-26-2005, 06:46 AM
Future303 Future303 is offline
Re: 95 Mustang Engine tapping noise
Could you be hearing Engine Ping? Try disconnecting the battery so your computer is reset.
Other than that, maybe check the timing with a timing light, and put a higher octane fuel to test it.
95 GT AKA "The Purple Hippo". Stock 302 bottom end. Edelbrock Heads. Performer 5.0 Intake, 1.7 RR's on stock Cam, Stock T5, 3.27 gears, UD Pullies, K&N Filter, rubber boot deleted, A/C deleted, BBK Catted X-Pipe, 180º TStat, EEC Tuner running J4J1 stock BIN. AEM WB02, Minor tunes, running pig rich. No clue as to RWHP feels a tad faster than a stock 05 GT.
Old 01-26-2005, 10:27 PM
silverstangs's Avatar
silverstangs silverstangs is offline
Send a message via AIM to silverstangs
Thanks
Pull the valve covers off, and wiggle every rocker. I would say one of them might be comming loose. It would also be a good time to check the lash on those rockers. If those check out find, then do a compression test...... start with the passenger side rear cyclinder since that one is most prone to busted head gaskets.
My ride at my site Silverstangs.
Old 01-29-2005, 10:14 PM
grapony grapony is offline
Send a message via AIM to grapony
Re: Re: 95 Mustang Engine tapping noise
If your heard the noise before the oil pressure got built back up it's a sure sign of rod bearing clearance. Gooseing the engine and letting it come back down is another way to hear the worn bearings also.
14 year auto tech from AL. Ask if you need some info.
Old 02-02-2005, 10:14 AM
Re: Re: Re: 95 Mustang Engine tapping noise
So what is involved in repairing this problem? Cost?
Old 02-02-2005, 12:33 PM
ModMech's Avatar
ModMech ModMech is offline
Another common 3.8L problem is the cam follower keepers breaking (they are plastic) allowing the follower to jump around on the cam, NOT GOOD. Ford switched to the plastic parts in the mid '90s, I'm not sure when exactly.
As suggested, it could also be main or rod bearings, but they sound "heavy", not like ticking.
Old 02-02-2005, 04:53 PM
The strange thing about this metal tapping sound is that you do not hear it when you drive the car around town at normal speeds and accelerations. You only hear when 1. fast acceleration and the rpms hit around 2500 or 2. in park reving the engine, then you hear it at around 1500 rpms. I feel the noise is loudest by the intake manifold on the top of the engine. But others think it is lower engine noise. Could the noise be reverberating up through the manifold from other parts of the engine?
