Old 01-24-2005, 10:42 PM
tspencer73 tspencer73 is offline
Exclamation Headlights won't shut off
At first the headlights would not work at all..I found that there was a problem with the blinker, wiper, dimmer switch. replaced it and headlights work fine.
Girlfriend hit deer and I had to replace driverside headlamp assembly. All the sudden the head lights will not shut off...even when the car is off and key is out switch is off. Lights still on. even pulled head light fuses and there still on. "I guess this black cable will work!" sure did.
Anyone have similar problem. Appreciate any help.
Thanks TS
Old 01-26-2005, 06:38 AM
denisb denisb is offline
I had a similar problem and it was my driving lights that were staying on. I pulled the driving light fuse and it solved my problem. Everything else works fine, low beam, high beam and auto lights.
Denis
Old 01-27-2005, 09:35 PM
low_on_air low_on_air is offline
head light won't go out
I had the same problem with my 1995 sho, I pulled the fuse under the hood and the lights still didn't go out. so I changed the day time running light module in the left inerfender behind the wheel well
