oil advice
I have a 89 s-10 4x4 blazer with over 200,000mi I have recintly done a oil flush and used 10w30 and a napa filter I think I want to flush it one more time and switch to syenthetic 5w30 but I dont know what filter and what oil to use. The guy at napa told me if I switch to syenthetic it will smoke alot more if it burns any oil is this true oh yeah it got a 4.3 tbi and any help would be great
Re: oil advice
Does your engine leak or burn oil now?
1995 Factory Blazer Service Manual for sale, PM if interested. |
Re: oil advice
yeah i got a littel white smoke but i dont mind smoke and i dont have emishions
Re: oil advice
no leaks
Re: oil advice
You are saying you get a little white water vapour out of your tailpipe?
That is normal especialy in the colder times of the year. Do you leak oil at all or ever have any blue smoke coming out of your tailpipe?
Re: oil advice
yup it drips a littel water to
Re: oil advice
no blue smoke or leaks
Re: oil advice
You should be good to go then, but I cannot fully guarantee that no leaks will come about after. More than likely nothing will occur and synthetic nowadays does NOT cause leaks. It will actually clean and re-swell seals and make them seal even better.
Now commence an oil flush routine and use a quality oil filter (NOT FRAM!), and I highly recommend Mobil 1 5w30 for your application.
Re: oil advice
will a napa filter work good the the truck had a fram on it when i got it
Re: oil advice
Yes, best to go with Napa Gold. They are made by WIX and are a very good oil filter.
Re: oil advice
do you have an idea how much a case of mobil 1 5w30 cost and i know fram is not a good filter but why
Re: oil advice
Just go to walmart and grab a jug for the oil change, you don't need to buy a case.
Fram is piss poor because their internal construction and filter media is expectionally poor.
Re: oil advice
thanx ill do that
I say go with the Mobil 10W30. It will keep better oil pressure when the engine warms up and will help reduce the chances of an oil leak compared to the 5W30. Mobil's 10W30 is designed for higher milage engines and where 10-30 is required(read its description). I am a strong believer of synthetics, as long as the engine is sound(no burning oil, no leaks etc) your good to go.
Re: oil advice
You have to understand that oil pressure is the resistance to flow and that is not something you want to do to an older engine, he requires proper flow to get to the top end for vital protection.
