Old 01-24-2005, 07:43 PM
G35turbo G35turbo is offline
Question Do I really need the Adjustable Rear Control Arms????
I am going to get the Tein S.Tech Springs and i am going to drop the front 1.5" and the rear 1.3" and i was wondering do i need the adjustable rear control arms. Is it really worth the $230 is there anyother website that has but cheaper.
Old 01-24-2005, 07:49 PM
xXxRocker5150's Avatar
xXxRocker5150 xXxRocker5150 is offline
Send a message via AIM to xXxRocker5150
Re: Do I really need the Adjustable Rear Control Arms????
If I think I read it correctly, on www.3sxperformance.com, it says that it'll help align the back almost perfectly or somthing, but did you look at 3sx???? they have some goodies there... o screw it I'll quit being a lazy ass... okay here's what 3sx has to say bout that
"One of the more common modifications people do to their Stealth and 3000GT is to lower it with aftermarket springs. The Catch-22 in lowering the car is that 9 times out of 10, even the best alignment shop will not be able to get the rear wheels back into acceptable specs as far as camber. Sometimes they can get things within a degree of negative camber, which up to a half or 3/4 degrees of negative camber shouldn't have too much affect on tire wear. But when they rear wheels end up 2.5 degrees out, the tires will wear uneven in a heartbeat! 3SX developed adjustable rear camber arms to alleviate the negative camber problem. Replacing the upper control arms on the TT/AWD models, and the lower camber and/or toe arms in the NA/FWD models, these control arms let you get the rear wheels back into near perfect spec so you will not wear out tires faster than normal." but they sell em' for like 300 buck-a-roos
Georgey on the subject of midget beastiality pornos
Originally Posted by 1viadrft
I've seen a video or two out of curiousity.... those damn midgets are hung! But then the donkey walks in...
Home Puta's 4Life Crew Member #1
R.I.P Andy, you will be missed by all.
Old 01-24-2005, 10:43 PM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
$120 and Ill ship you the ones I made
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
Old 01-24-2005, 11:13 PM
Do you have any pictures of it???
Old 01-25-2005, 02:16 AM
Jt to make sure they are for a turbo car, and I can get pictures my next day off, so wed or thursday.
Old 01-25-2005, 07:58 PM
ohh ok
Old 01-27-2005, 03:33 AM
Looks like I may keep these. If you head over to www.us3s.com I know they have them in the sub $200 range.
