Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 01-24-2005, 07:40 PM
drpaul87 drpaul87 is offline
Possible bad alternator??
97 Rodeo, 3.2L. Cold weather has finally hit here in Pa (tested the 4wd and this truck is an animal in the snow). Started it to warm it up, volt gauge reads 12 when idling. Start to drive and it hits 14v, and stays there. Only on 12 Volt when idling at startup. Bad alternator? Thank you again for this forum.
Paul
Old 01-24-2005, 07:45 PM
2eyefishclaw's Avatar
2eyefishclaw 2eyefishclaw is offline
Send a message via AIM to 2eyefishclaw Send a message via Yahoo to 2eyefishclaw
Re: Possible bad alternator??
normal dont worry about it
Old 01-24-2005, 09:47 PM
Tonupboy Tonupboy is offline
Send a message via AIM to Tonupboy
Yeah, Rodeos are weird, one thing I learned about driving my 93 4wd Rodeo, if it ain't broken, don't fix it...fix it...it has quirks which doesnt bother me at all...like the alternator...it does it once in a while...I was worried at first but she starts great in the morning..
_________________
T O N U P B O Y
"That which does not become a part of the one, shall become one with the void."
Allegiance: None
Function: Universal Dominator
2001 Nissan Pathfinder
1993 Isuzu Rodeo 4WD V6
Old 01-24-2005, 10:55 PM
rodeo02 rodeo02 is offline
Paul
If you are basing your volt readings from the dash gauge, yes. No worries, they are very inaccurate.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 01-26-2005, 05:38 PM
plurge plurge is offline
Re: Re: Possible bad alternator??
G/luck
Joel
I was having the same problems this weekend but my lights were strobing. It ended up being the alternator. My assumption is if everything is working properly, then everything is fine. If you have problems starting or if your dash lights start coming on or your gauge starts fluctuating then you've got a problem.
