Old 01-24-2005, 06:53 PM
Old and good Old and good is offline
Send a message via MSN to Old and good
Automatic problems
im checking if any of you guys know what the problem is with my automatic..... Well after a good burnout on my firebird i began to drive away and the trany went bad. it seems to shift good but if i rev above about 2500rpm's the shift is realy hard....
i mean it jerks like something is going to brake! i have also noticed that the car began to bleed alot of transmission oil and i have parked my car because im afraid to drive while there is something wrong
i dont think the tranny itslf is failing as the only problem is the shifts and if i accelerate fast and just remove my foot of the throttle berfore the shift the car shifts good. and the trany is recently rebuilt.
have you guys any solutions to my problem?
Old 01-25-2005, 05:13 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: Automatic problems
Smell the tranny fluid and see if it smells burnt. Could have very well burnt up some bands
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 01-25-2005, 07:12 PM
its to late to smell it because the fluid leaked so much from the car that i have alredy added 700ml of trans-oil.
is this a big problem to fix? i am looking to try and fix it myself as a transmission rebuild in my country costs about 4-5k dollars!
Old 01-25-2005, 07:28 PM
tacoma man.'s Avatar
tacoma man. tacoma man. is offline
Send a message via Yahoo to tacoma man.
were are you from old and good?
Old 01-25-2005, 07:48 PM
Iceland. the problem with importing things. e.g. air filter i orderd for my other car it cost 67$ with shipping but when the customs were trhu i ended up paying 183$!!!!!
Old 01-25-2005, 08:46 PM
CreepingDeath94 CreepingDeath94 is offline
I believe if bands were burnt up it would slip, not shift harder. There could be some dirt or something obstructing the fluid from flowing to a specific area in the tranny when shifting at high rpms...I would try and get the tranny flushed first. Also, when flushing it, clean the tranny off real well and see where exactly the leak is coming from.
Old 01-25-2005, 09:16 PM
what exactly is flushing? it wuld not surprize me if a gasket failed! i was doing a burnout on some 275/45/18 pirelli tires and it probably was wery hard for the trany. on the outside the transmission leaks in many different places. i have to but a can below the car when i have turned it off becouse it leaks for some time after i have turned the engien off
Old 01-25-2005, 09:53 PM
A dealer or mechanic basically runs solution through the tranny to get all the dirt out and fills it with new oil and a new gasket.
Old 01-26-2005, 07:17 AM
does that explain the leak from the trasmission? and does flushing involve taking the transmission from the engien?
Old 01-26-2005, 07:25 AM
custom mccannix custom mccannix is offline
Send a message via AIM to custom mccannix
the leaks are probably the seals but the shift could be ballooned torque converter dirt in the vavle body or a stripped of 1-2 shift valve it may need to go to a pro to look at alot could be wrong
Old 01-26-2005, 01:01 PM
heh it seems this is gonna cost me. this is the downside ot these cars in my opinion. the trany is always failing. my friend has had to rebuild his 3 times now. and when he finaly sold the car the new owner ended up with a busted trany 2 days later
Old 01-26-2005, 08:50 PM
chickenkicker's Avatar
chickenkicker chickenkicker is offline
What make/year is your car
Black 97 Trans Am M6 - TB Bypass, !CAGS, Manual Fan Switch, 1LE Elbow, K&N FIPK, SLP Loudmouth Exhaust, cross drilled and slotted rotors.
Click here to visit my CarDomain page
Old 01-26-2005, 09:00 PM
hotrod_chevyz's Avatar
hotrod_chevyz hotrod_chevyz is offline
sounds like you need a tranny mount,shift kit and a pan gasket.If its been recently rebuilt,all you need is a transgo shift reprogram kit,wich will allow you to select a softer shift.The external leak is probably an o-ring or pan gasket seal.Worst cause scenario the pump screws came loose,or a line needs replaced.A decent shop shouldnt charge too much to install the shift kit But dont get a B&M shift kit.Since you say its been recently rebuilt,and the problem is the shift is too firm,i would imagine it can be fixed,without the transmission having to be separated from the engine.
Another thing to consider,is replacing the valve body of the trans completely.But i bet you could just get away with a shift kit,to soften up your shift and save the tranny from breaking a sprag or somthing else.
Old 01-27-2005, 06:56 PM
its a 1995 firebird v-8 convertible (save the jokes of owning a convertible in iceland).......
when the car shifts it realy bangs!!!! and not a little when driving i can feel the trany jerking when it shifts gears. and note that this hapens only @ 2500rpm's+.... i first thought (dont know the word in english) that it was a malfunction in the thing that conects the drive shaft to the rear axle.
Old 01-27-2005, 07:01 PM
Could it be a bad trans mount? My old fwd dodge had a bad tranny mount and it banged hard when it shifted at higher RPMs.
