Old 01-24-2005, 05:49 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
fiberglass work
ok, i dont feel like doing an internet serch and looken through piles of shit, so does anyone know a good site or have some advice for someone whos never worked with the stuff, im looken to fill 2 fender holes, do the dash, and shave some stuff off... also where can i get fiberglassing materieals?? thanks all
Old 01-24-2005, 06:50 PM
91HBSi 91HBSi is offline
Send a message via ICQ to 91HBSi Send a message via AIM to 91HBSi Send a message via Yahoo to 91HBSi
Honestly, I wouldn't advise you to do body work with FG; unless it's fender flares or something.
Advice. Make sure you buy room temp. resin... so you don't have to cure it at like 200 degrees. Put enough layers. I don't know how many would be needed on a dash, but I would be guessing like 5-6. Let the first layer be tightly woven FG cloth if you plan on painting it,this will make it easier. When you lay it up, lay the layers like this - / l \ - . I don't know if that makes sense, but you lay your first layer horizontal or vertical then lay a 45 degree and then another horizontal/vertical and so forth and so on.
I don't know if you've ever seen this, but you could take your dash out and lay carbon fiber cloth over it with resin and let that harden... then come back with clear coat. That looks really good. I would say that if your dash is not black then you should dye/paint it black before doing that though, because the color might show through the gaps in the fiber.
Oh, and this is all going to be relatively expensive.
Lexus SC300 (Kazera KZa 18"x8.5" 245/40 (front), 18"x9.5" 275/35 (rear)... put on hold.
Civic Hatchback Si (I/H/E, d16z6 head, H&R springs/tokico blues, etc.)
94 Prelude Si (Sold!)
Former PureHonda.com member since Dec. 00
"For to me, to live is Christ and to die is gain." Pilippians ONe21
Old 01-24-2005, 06:54 PM
Re: fiberglass work
it is my fenders, and it may be a little more expencive then sheet metal, but i dont have a mig or tig welder, and when i graduate in like 4 months i no longer have axcess to one, so i was hopeing to get into fiberglass/cf work now and not learn it out of necesity in a few months
