Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 01-24-2005, 03:09 PM
jumblenuts jumblenuts is offline
Car Wont Start
Hi,
My car seems to be unable to start had a battery problem replaced battery ran for a couple of days and then wont start. Started a couple of times but it would kick like the gas was't getting to it. Thought it might be frozen lines so I pored heet into it to remove water and unfreeze it. After troubleshooting some more I then turned the key to listen to see if the pump came on. No sound. So I then read a little and come to the conclusion its either a bad fuel pump relay or a bad fuel pump. My question is does anyone know how to bypass/jump the relay so I can elimiate weather it is that or not and also so I can get the car started so I can move it. Any other thoughts are welcome. Also checked the inertia switch and it was still pressed down so I know it isn't that.
Thanks
Old 02-20-2005, 04:05 PM
bdub41778 bdub41778 is offline
Re: Car Wont Start
what year? did you check the filter?
