Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 01-24-2005, 01:41 PM
yvonne46746 yvonne46746 is offline
coolant temp sensor
i need to locate the coolant temp sensor for my 97 aurora, and i need the wiring diagrams if anyone could please help me... location of the sensor, etc....
thanks
yvonne
Old 01-25-2005, 05:26 PM
treeboy38's Avatar
treeboy38 treeboy38 is offline
i believe the coolant temp sensor located on the bottom of the overflow tank (i think it is attached to the tank itself).
1997 Burgandy Aurora
Old 04-30-2009, 05:01 PM
theroadisalover theroadisalover is offline
Re: coolant temp sensor
I realize this thread is old, but the temp. sensor is in the right head, at the end, close to the master cylinder/vacuum assist drum. This is just a ref. the sensor is down on the lower part of head behind a bunch of plumbing, wiring, hoses...you name it. Its a bitch to get to. However....this is the "TEMP.SENSOR" that sends info to the temp. gauge (analog) on the dash. The "low coolant" sensor is under the recovery bottle....and I mean under the bottle, i,e.....Go ahead and detach bottle from apron. Its easier in the long run.
Hope this helps someone who is "in the dark" on these issue's.
Theroad
