Go Back   Automotive Forums Car Chat > Nissan > Cedric | M45 | J30 | Gloria
Old 01-24-2005, 12:26 PM
onesourcerms onesourcerms is offline
Angry parking lights won't go off
On 94 j30 when headlight switch is turned off, dash and parking lights won't go off - kills battery. Any suggestions from anyone who had this problem? Thanks
Old 01-24-2005, 03:03 PM
infinman infinman is offline
What year J ?
Old 01-24-2005, 03:26 PM
Re: parking lights won't go off
Originally Posted by onesourcerms
94 J30. When headlight switch is turned off, dash and parking lights won't go off - kills battery. Any suggestions from anyone who had this problem? Thanks
1994
Old 01-25-2005, 01:16 AM
Nahkapohjola's Avatar
Nahkapohjola Nahkapohjola is offline
Re: Re: parking lights won't go off
1994
Light switch.
Disconnect sw connector -->lights off?
If so, replace.
Maxima INFO pages was deliberately trashed (!?) by Cardomain; dont goto http://www.cardomain.com/ride/748507
There was a special Car Electronics -page http://www.cardomain.com/ride/748507/14
Old 01-25-2005, 07:13 PM
Thanks for ditching the red font.You have either a bad headlamp switch or taillamp relay{also powers illumination}.Quick test.Remove panel where your interior fuse box is.Behind you will find some relays.Disconnect the blue relay{taillamp relay}.Ensure dashlights go out.Open your hood.Remove cover for relays.Steal a blue relay and install where taillamp relay was removed.All Nissan relays are coloured coded.All blue relays are the same.They are called a 1M {1 make} relay.If lights now work normal, you have a stuck relay.If not, it's definately the headlight switch.
What you are doing here is jumping into the middle of the circuit and this test will tell which direction to go.Upstream or downstream.
Good luck
