Old 01-24-2005, 10:14 AM
ddegen ddegen is offline
Cavalier power drivers window cold weather malfunction
The driver's window in my 2002 Cavalier does not function in cold (below freezing) weather. The other three windows work fine. The driver's window works fine in warm weather. I know of one other Cavalier with the same problem.
Has anyone seen this before?
Old 01-24-2005, 10:40 AM
z24 fanatic z24 fanatic is offline
Send a message via AIM to z24 fanatic
Re: Cavalier power drivers window cold weather malfunction
just moved to cold weather inviroment and my driver side door lock sticks sometimes i was told it is normal though
Old 01-24-2005, 01:44 PM
HeadlessHorseman's Avatar
HeadlessHorseman HeadlessHorseman is offline
Send a message via AIM to HeadlessHorseman
You might try getting some ArmorAll and soaking an old rag with it. Push the rag into the window channel and clean the hell out of it - sides, top and bottom. The ArmorAll, even when dry, will act as a lubricant and allow your windows to go up and down much more easily. I had the same problem my my '95 Rodeo and this solution worked great... in hot and cold weather.
