Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 01-24-2005, 09:35 AM
unreal5 unreal5 is offline
Slow to catch and start
I have a 1997 Jeep GC Laredo with 90K. When I go to start my Jeep, it gives a hesitation, like it is trying really really hard to start and then will catch and be fine. I don't have to give it any extra gas, it just hesitates until it starts. Then I'll drive it and be fine. Finally the other day, I go to start it and all the lights light up but it just starts clicking and now won't turn over. Any ideas as to what this could be? Anyone experience this either? Thanks
-Anthony
Old 01-27-2005, 05:06 AM
Cam7 Cam7 is offline
First make sure your battery is up to charge a weak battery in winter weather will make it diffucult to start. Try cleaning the batterry connections with a wire brush and a file or sandpaper. Have to have a good connection. If the Battery is good and the connections are clean you have starter issues which you will probally have to replace the starter. Not that bad of a Job.
Old 01-27-2005, 06:33 AM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
Re: Slow to catch and start
Does sound like a battery problem, after recharging/cleaning the Battery and cables.
and still have the slow start problem try this, turn the key to the ON position for about 5-10 seconds, then turn off and try to start the engine. If it starts right up then the fuel pressure is feeing back into the tank. Prolly a bad Fuel Pressure Regulator.
Old 01-27-2005, 01:11 PM
Thanks
I appreciate your help, I will do those things and see. It is most likely a battery issue. Thanks again.
-Anthony
Old 01-30-2005, 09:55 PM
Thanks
Great job guys, it was the battery. Finally, everything just died. When I would start up I would get a little bit of power and then nothing. I had a new battery put in and everything works 100%. So, if the car has a bit trouble starting, may not be the starter but probably just the battery is dead.
-Anthony
Old 01-30-2005, 11:25 PM
good to hear you got the JEEP runnin'
