Go Back   Automotive Forums Car Chat > Mazda > 626/Capella/Capella Wagon
Old 01-24-2005, 08:41 AM
Mac626's Avatar
Mac626 Mac626 is offline
Question 98 626 EGR Valve
My check engine light is on and my 626 is running a tiny bit rough. I stopped at Autozone and did the magic code reader thing. They say it is the EGR valve and/or two sensors that feed it. The guy recommended I remove it, test it, clean it up, and re install it before trying to buy a new one (at $399.00 I agree). I looked in my Haynes book and there is all the testing information I need, but it does not show the valve or it's location on my car.
Can anyone tell me where to find this thing?
Old 01-27-2005, 12:10 AM
mazdatech mazdatech is offline
Re: 98 626 EGR Valve
What motor? What code number exactly? what are the miles?
Old 01-27-2005, 08:00 AM
Mac626's Avatar
Re: Re: 98 626 EGR Valve
It's the 6 cylinder, and I didn't get the exact code number. In his book when he looked it up it referenced the EGR valve, a solenoid and a sensor. Mileage is 120K (1998 626).
Old 02-25-2005, 10:19 PM
DP_626V6 DP_626V6 is offline
Unhappy
I have exactly the same problem. Check engine was coming on and off every couple days and finally when it stayed on for a longer time I checked the code in Autozone. It read "EGR flow" code P0400. It's 98 626 V6 with 126k miles. Mac626, did you find out what was wrong?
Does anybody know what can cause that?
Old 02-28-2005, 08:22 AM
Mac626's Avatar
The guy told me the valve needs to be replaced ($400.00 for the part only ). He also said that sometimes removing it and cleaning it will solve the problem. My Haynes book doesn't show where it is located and I haven't had the opportunity to mount a search for it yet.
Old 06-16-2005, 08:53 AM
davegnh davegnh is offline
I have a 1998 with a 4 cyl, does anyone know where the EGR is on this motor? Is it under the air filter assembly?
Old 06-16-2005, 12:27 PM
bbrd177 bbrd177 is offline
Re: Re: Re: 98 626 EGR Valve
Go to Autozone.com. They have a repair section that may help..
Old 06-23-2005, 07:02 AM
James Tharp James Tharp is offline
Similiar
Same thing but on a 1999
The dealer said that the egr was bad at first but then they changed their mind. Now they say that the bus cable that goes to the check engine light has a short in it. What ever. Im going back to auto zone and try some stuff my self.
Old 06-29-2005, 09:36 PM
cswor cswor is offline
Re: Re: Re: Re: 98 626 EGR Valve
on my 94 (4 cyl 626 autotrans), it is located under the throttle body which means you have to remove the air pipe from the filter/map and so on to get to it. it looked like taking it off mine would be a pain in the -ss since its toward the back of engine. fortunately, mine could be tested in place. of course i haven't gotten to the root of my problem yet.
